Brother HL-L6300DW A4 Mono Laser Printer With Free LT-5505 Tray
Quicklinx: CHQLWS00 Mfr#: HLL6300DW+LT5505PROMO
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Open up new business opportunities with this robust machine. Offering excellent paper handling options, super fast print speeds and the new optional super-high-yield toner cartridges significantly reduces your print spend, making this machine the ideal print partner for your business.
Printer comes with free LT-5505 Tray!
Maximise Performance & Reduce Print Spend
Versatile paper handling, enables you to add multiple lower trays, and mailbox options across the range. This provides maximum device uptime, as less time is spent replenishing paper trays and searching for your printed documents. With the optional high yield toner cartridges, productivity is enhanced, whilst reducing your overall printing costs.
Better reliability
Built to perform for longer and meet the demands of high output work environments, the L6000 range has been totally remodelled with robust build quality that’s even more resilient and hardwearing.
Enhanced Workflow
The L6000 range introduces an intuitive and user-friendly interface, and support for multiple business cloud based services including Dropbox and Google Drive.
Tighter security
In today's business environment, we understand that organisations demand the highest levels of security. In order to address this, the L6000 range is enabled with secure function lock 3.0, 802.1x and Internet Protocol Security (IPsec). The range also boasts Print Archive, Secure Reset, Certificate Management and Near field communication (NFC) functionality for secure user access and authentication.
Flexible print solutions from Brother
Our L6000 range is designed to seamlessly integrate and meet your business requirements. Compatible with a range of print software and services, Brother Solutions enables you to maximise your print efficiency and minimise costs, specifically tailored to your requirements.
Eco-friendly
The L6000 range is compliant with a number of environmental standards including German Blue Angel, Nordic Swan and Energy Star. As a result, not only does it help your business work more efficiently, it is also more energy efficient, reducing impact on the environment and lowering your costs at the same time.
  • Fast, high-quality printing for higher print volumes
    Featuring a business-durable design with an impressive print speed of up to 48 pages per minute, this high-performance printer is ideal for mid-sized workgroups. Plus, it offers up to 1200 x 1200 dpi resolution for crisp, clear text and excellent graphics.
  • Low total cost of ownership
    Includes a high-yield 8,000-page toner cartridge for built-in value. For even lower cost printing, use the super high-yield 12,000-page replacement toner cartridge.
  • Large, expandable paper capacity
    Easily handle your large print jobs via an adjustable 520-sheet capacity paper tray and 50-sheet capacity multi-purpose tray. Additional optional paper trays are available in 250-sheet or 520-sheet capacities, enabling users to configure the printer with multiple trays in a way that best meets their application requirements - up to 1,610 sheet total capacity.
  • Flexible network connectivity
    Built-in wireless 802.11b/g/n and Gigabit Ethernet network interfaces allow you to share the HL-L6300DW with multiple users on your network.
  • Print from your mobile device
    Print from your mobile device via: AirPrint, Google Cloud Print 2.0, Mopria, Brother iPrint&Scan, NFC, Cortado Workplace and Wi-Fi Direct
  • Automatic two-sided printing
    Use the duplex feature to produce professional brochures, documents and booklets. This feature can help save money and cut your paper usage by up to 50%.
  • Adjustable, 1.8" color Touchscreen display
    Offers intuitive menu navigation and printing from popular business cloud services‡ including: DROPBOX, GOOGLE DRIVE, ONEDRIVE, and more
  • Advanced security features
    Includes an integrated NFC card reader and Active Directory support for network user authentication to help protect against unauthorized access to the device. Other security features include: Secure Function Lock, Enterprise Security (802.1x), IPSec, Secure Print, SSL/TLS and more.
Brother HL-L6300DW - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
13.2 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 48 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 46 ppm - B/W - A4 (210 x 297 mm) , Up to 24 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 24 ppm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n), NFC
Preview Screen Size
1.8"
RAM Installed (Max)
256 MB
Language Simulation
PCL 6, XPS, BR-Script3, IBM ProPrinter XL, EPSON FX-850, PDF 1.7
Media Type
Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, thin paper
Total Media Capacity
570 sheets
Media Handling
50-sheet multipurpose tray, 520-sheet input tray
Recommended Monthly Volume
7500 pages
Print server
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Microsoft Windows Server 2012 R2 x64 Edition, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11
3-year warranty
40 cm x 28.8 cm x 39.6 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Preview Screen Size
1.8"
Wired
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
7.5 sec
Language Simulation
Media Handling
RAM
RAM Installed (Max)
256 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
Media Weight
60 g/m² - 200 g/m²
570 sheets
Media Feeders
1 x automatic - 520 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , 1 x automatic - 50 sheets - 215.9 x 355.6 mm weight: 60 g/m² - 200 g/m²
Output Trays Capacity
260 sheets
Duty Cycle
7500 pages
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
Security Protocols & Features
Kerberos, SSL, TLS, IPsec, 802.1x, ARP, PEAP
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 8000 pages , 1 x drum
Power supply - internal
Frequency Required
50/60 Hz
740 Watt
Power Consumption Stand by
32 Watt
Power Consumption Sleep
1.6 Watt
Environmental Standards
Blue Angel
ENERGY STAR
Limited warranty - replacement - 3 years
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Idle)
35 dBA
Sound Emission (Operating)
54 dBA
Sound Emission (Quiet Mode)
50 dBA
40 cm
28.8 cm
39.6 cm
13.2 kg
Width (Shipping)
49.7 cm
Depth (Shipping)
49.2 cm
Height (Shipping)
42.7 cm
Weight (Shipping)
15.8 kg
Ink (4)
CHQL Brother TN-3430 Black Standard Yield Toner In Stock £60.32
CHQL Brother TN-3480 Tonert 8000 Pages In Stock £102.33
CHQL Brother TN-3512 Black Super High Yield Toner In Stock £117.98
CHQL Brother HLL6400/MFCL6900DW/T Drum Unit 30K In Stock £120.09
Other bundles (2)
CHQL Brother LT5505 250 Sheet Optional Paper Tray In Stock £111.84
CHQL Brother LT6505 520 Sheet Optional Paper Tray In Stock £114.22
