Brother HL-L2340DW Mono Laser Printer
Quicklinx: 9NJKWS00 Mfr#: HLL2340DWZU1
  • Windows 8 (32/64 bits)
A perfect Mono Laser printer for connected Small Offices. Print high-quality documents in black and white with the touch of a button with this tablet and Wi-Fi enabled, mobile print compatible machine.
With print speeds of up to 26ppm your documents can be ready before you arrive at the printer to pick them up. The 250 sheet paper tray allows you to spend more time creating your documents instead of reloading an empty paper tray to print them.
Also prepare to print from anywhere, using the Brother iPrint&Scan app, Google Cloud Print, Apple AirPrint and Wi-Fi Direct you can send your documents to print using your tablet or mobile device.
With efficiency in mind, the double-sided printing feature and optional, high-yield toner cartridges you can expect reduced waste and costs.
  • Flexible connectivity
    Provides built-in wireless 802.11 b/g/n, and Wi Fi Direct to share with others on your network. Eliminate extra cables and conveniently place your printer with wireless networking or connect locally to a single user via its High-Speed USB 2.0 interface.
  • Easily print two-sided documents
    Produce professional two-sided documents, brochures and booklets using the automatic duplex printing feature. This feature can reduce your paper use and help save money.
  • Convenient paper handling
    The HL-L2340DW can meet all of your printing needs via an adjustable, 250-sheet capacity paper tray‡ that handles letter or legal size paper and a manual feed slot for printing envelopes and letterhead.
  • Straight-through paper path
    A manual feed slot and rear paper exit provide a straight-through paper path to ensure that all of your printed materials always look their best.
  • Fast, high-quality output
    Helps improve your productivity with a print speed of up to 27 ppm and produces crisp text and excellent graphics at up to 2400 x 600 dpi.
  • Toner save mode
    Use less toner and save money by using Toner Save mode for your less critical business documents.
Brother HL-L2340DW - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
6.9 kg
Media Size Class
A4
Max Media Size
215.9 x 355.6 mm
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 26 ppm - B/W - A4 (210 x 297 mm) , Up to 13 spm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
2400 x 600 dpi
Image Enhancement Technology
Brother HQ1200
Automatic Duplexing
USB 2.0, Wi-Fi(n)
AirPrint Enabled
RAM Installed (Max)
32 MB
Language Simulation
Windows GDI driver
Media Type
Plain paper, bond paper, recycled paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet manual tray
Recommended Monthly Volume
250 - 2000 pages
Print server
Linux, Microsoft Windows XP Home Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows XP Professional (32/64 bits), Apple MacOS X 10.7.5, Apple MacOS X 10.9.x
Microsoft Certification
Compatible with Windows 7
35.6 cm x 36 cm x 18.3 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wireless
USB 2.0, Wi-Fi(n)
AirPrint Enabled
2400 x 600 dpi
Brother HQ1200
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Language Simulation
Windows GDI driver
Media Handling
RAM
RAM Installed (Max)
32 MB
Media Handling
Media Type
Media Size Class
A4
Max Media Size
215.9 x 355.6 mm
76.2 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 76.2 x 127 mm, 215.9 x 355.6 mm
Media Weight
60 g/m² - 163 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , 1 x manual - 1 sheet - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m²
Output Trays Capacity
100 sheets
Duty Cycle
250 - 2000 pages
Print server
Security Protocols & Features
WEP, WPA-PSK
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 700 pages , 1 x drum - up to 12000 pages - Brother DR2300
Environmental Standards
Blue Angel
ENERGY STAR
Nordic Swan Ecolabel
Sound Emission (Idle)
30 dBA
Sound Emission (Operating)
49 dBA
Sound Emission (Quiet Mode)
45 dBA
35.6 cm
36 cm
18.3 cm
6.9 kg
Width (Shipping)
44.1 cm
Depth (Shipping)
28.6 cm
Height (Shipping)
50.4 cm
Weight (Shipping)
8 kg
