A truly cost-effective Mono Laser printer, that's perfect for Small Office use. Offering professional quality printing at speeds of up to 26ppm you can rely on the HL-L2300D to deliver your documents quickly and to the highest standard.
The large 250 sheet paper tray allows this compact machine to work harder than its size suggests, while the 1 sheet manual feed is perfect for envelopes and special media.
With double-sided printing, as standard, and optional cost-effective, high-yield toner cartridges long-term costs and unnecessary waste can be greatly reduced.
Fast laser printing
It helps improve your productivity with a high print speed. -
Easily print two-sided documents
Produce professional two-sided documents, brochures and booklets using the automatic duplex printing feature. This feature can reduce your paper use and help save money. -
High-quality output
With a high print resolution, the HL-L2300D produces professional output with crisp text and excellent graphics. -
Convenient paper handling
The Brother HL-L2300D personal laser printer can meet all of your printing needs via an adjustable paper tray that handles letter or legal size paper and a manual feed slot for printing envelopes and letterhead. -
Toner save mode
Use less toner and save money by using toner save mode for your less critical business documents. -
Straight-through paper path
A manual feed slot and rear paper exit provide a straight-through paper path to ensure that all of your printed materials always look their best.
- Brother HL-L2300D - printer - B/W - laser
- Printer Type
- Personal printer - laser - B/W
- 6.9 kg
- Media Size Class
- A4
- Max Media Size
- 215.9 x 355.6 mm
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 215.9 mm x 355.6 mm
- Print Speed
- Up to 26 ppm - B/W - A4 (210 x 297 mm) , Up to 13 ipm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 2400 x 600 dpi
- Image Enhancement Technology
- Brother HQ1200
- Automatic Duplexing
- Interface
- USB 2.0
- RAM Installed (Max)
- 8 MB
- Language Simulation
- Windows GDI driver
- Media Type
- Plain paper, bond paper, recycled paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet manual tray
- Recommended Monthly Volume
- 250 - 2000 pages
- System Requirements
- Linux, Microsoft Windows XP Home Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows XP Professional (32/64 bits), Apple MacOS X 10.7.5, Apple MacOS X 10.9.x
- Microsoft Certification
- Compatible with Windows 7
- 35.6 cm x 36 cm x 18.3 cm
- Printer Type
- Personal printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB 2.0
- 2400 x 600 dpi
- Brother HQ1200
- First Print Out Time B/W
- 8.5 sec
- Media Handling
RAM
- 8 MB
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- 215.9 x 355.6 mm
- 76.2 mm x 127 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 76.2 x 127 mm, 215.9 x 355.6 mm
- Media Weight
- 60 g/m² - 163 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , 1 x manual - 1 sheet - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m²
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 250 - 2000 pages
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages ISO/IEC 19752 , 1 x drum - up to 12000 pages - Brother DR2300
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Nordic Swan Ecolabel
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 49 dBA
- Sound Emission (Quiet Mode)
- 45 dBA
- 35.6 cm
- 36 cm
- 18.3 cm
- 6.9 kg
- Width (Shipping)
- 44.1 cm
- Depth (Shipping)
- 28.6 cm
- Height (Shipping)
- 50.4 cm
- Weight (Shipping)
- 8 kg
