Brother HL-6180DWT High Speed Mono Laser Printer
Quicklinx: 87GNWS00 Mfr#: HL6180DWTZU1
The HL-6180DWT has been developed with the larger offices in mind.
First and foremost it's a printer that's firmly rooted in Brother's commitment to durable engineering. That's why, even at 40ppm and with 1,200dpi resolution, this robust printer handles it all, day in, day out.
The standard paper capacity is a hefty 1,050 sheets, with a super high-yield 12,000-page toner cartridge supporting automatic duplex and booklet printing.
And with Ethernet and Wi-Fi connectivity, the HL-6180DWT is easily integrated in to a host of different business systems.
Brother HL-6180DWT - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
14.6 kg
Media Size Class
A4
Max Media Size
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
69.8 mm x 116 mm
Max Media Size (Custom)
216 mm x 406.4 mm
Print Speed
Up to 40 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB, Gigabit LAN, Wi-Fi(n)
400 MHz
RAM Installed (Max)
128 MB (384 MB) - DDR2 SDRAM - SO-DIMM 144-pin
Language Simulation
PCL 6, BR-Script3, IBM ProPrinter XL, EPSON FX-850
Media Type
Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, thick paper
Total Media Capacity
1050 sheets
Media Handling
2x 500-sheet input trays, 50-sheet multipurpose tray
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Linux, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Apple MacOS X 10.5.8, Apple MacOS X 10.6.x, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x
1-year warranty
37.1 cm x 38.4 cm x 41.8 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wireless
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
8.5 sec
Language Simulation
Fonts Included
66 x scalable , 66 x scalable PostScript , 13 x barcode , 12 x bitmapped
Media Handling
400 MHz
RAM
RAM Installed (Max)
128 MB / 384 MB (max)
Technology / Form Factor
Slots Qty
1
Empty Slots
1
Media Handling
Media Type
Media Size Class
A4
Max Media Size
69.8 mm x 116 mm
216 mm x 406.4 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B6 (125 x 176 mm)
Media Weight
60 g/m² - 163 g/m²
1050 sheets
Media Feeders
1 x automatic - 50 sheets - 216 x 406.4 mm weight: 60 g/m² - 163 g/m² , 2 x automatic - 500 sheets - ANSI A (Letter) (216 x 279 mm) weight: 60 g/m² - 105 g/m²
Max Media Capacity
1050 sheets
Output Trays Capacity
150 sheets
Print server
Network / Transport Protocol
TCP/IP, NetBEUI/NetBIOS, ICMP/IP, LPR/LPD, ARP, SMTP, BOOTP, DHCP, RARP
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP
Security Protocols & Features
Secure Print, WEP, WPA-PSK, TLS, 802.1x, WPA2-PSK
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge - up to 8000 pages ISO/IEC 19752 - Brother TN3380 , 1 x drum - up to 30000 pages - Brother DR3300
Power supply - internal
701 Watt
Power Consumption Stand by / Sleep
4.9 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
Sound Emission (Idle)
34 dBA
Sound Emission (Operating)
59 dBA
37.1 cm
38.4 cm
41.8 cm
14.6 kg
Width (Shipping)
66.4 cm
Depth (Shipping)
50.3 cm
Height (Shipping)
70.2 cm
Weight (Shipping)
20.9 kg
