The HL-5450DN offers ultimate reliability, speed and flexibility, coupled with easy Ethernet connectivity.
With a high-speed output of up to 38ppm and 1200dpi, you'll get both speed and professional print quality from a standard paper tray capacity of 300 pages.
There's also duplex printing functionality and booklet capability so you can produce all kinds of professional documents economically. Add in the option of an up to 8,000 page high-yield toner cartridge, and it's easy to see why the HL-5450DN makes smart business sense.
Fast, high-quality output
With a print speed of up to 40 pages per minute, this printer is ideal for busy offices. Plus, it offers up to 1200 x 1200 dpi resolution for crisp, clear text and excellent graphics. -
Flexible connectivity
Share with others via its built-in Ethernet interface or connect locally via its Hi-Speed USB 2.0 interface. -
Cost efficient performance
Spend less time replacing supplies and help reduce running costs with high-yield 8,000-page replacement toner cartridge. -
Versatile paper handling
The Brother HL-5450DN offers an adjustable 250-sheet capacity paper tray for letter or legal size paper and a 50-sheet capacity multi-purpose tray for printing letterhead and custom paper sizes. -
Automatic duplex printing
Produce professional two-sided documents, brochures, and booklets with ease. Duplex printing can help save money and reduce your paper use. -
Advanced security features
Provides a wide-range of security features including: secure function lock, enterprise security and more.
- Brother HL-5450DN - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 10.4 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 215.9 mm x 355.6 mm
- Print Speed
- Up to 38 ppm - B/W , Up to 18 ppm - B/W duplex
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB, LAN
- Processor
- 400 MHz
- RAM Installed (Max)
- 64 MB (320 MB) DIMM 144-pin
- Language Simulation
- PCL 6, BR-Script3, IBM ProPrinter XL, EPSON FX-850
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Networking
- Print server - Ethernet, Fast Ethernet
- System Requirements
- Linux, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition, Apple MacOS X 10.5.8, Apple MacOS X 10.6.x, Apple MacOS X 10.7.x
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 37.1 cm x 38.4 cm x 24.5 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 8.5 sec
- Fonts Included
- 66 x scalable PCL , 66 x scalable PostScript , 12 x bitmapped PCL
- Media Handling
- Processor
- 400 MHz
RAM
- 64 MB / 320 MB (max)
- Technology / Form Factor
- DIMM 144-pin
- Slots Qty
- 1
- Empty Slots
- 1
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm), 76.2 x 127 mm, 215.9 x 355.6 mm
- Media Weight
- 60 g/m² - 163 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x automatic - 50 sheets - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 800 sheets
- Output Trays Capacity
- 150 sheets
- Networking
- Print server
- Data Link Protocol
- Connections
- 1 x USB 2.0 , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages ISO/IEC 19752 , 1 x drum - up to 30000 pages
- Power Device
- Power supply
- 700 Watt
- Power Consumption Stand by / Sleep
- 4.8 Watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - 1 year
- Sound Emission (Operating)
- 59 dBA
- Sound Emission (Quiet Mode)
- 54 dBA
- 37.1 cm
- 38.4 cm
- 24.5 cm
- 10.4 kg
Brother DR-3300 Drum Unit | In Stock | £112.89 |
Brother TN3330 Toner Cartridge - Black | In Stock | £62.04 |
Brother TN3380 Black Toner Cartridge | In Stock | £97.78 |
