Brother HL 5240L - printer - B/W - laser
Quicklinx: 50MNWS00 Mfr#: HL5240LZU1
For business quality printing, whether at home or in the office - the Brother HL-5240L is the ideal, low cost printer. Quick and easy to install, the HL-5240L printer has state-of-the-art interactive animations to help get the most from this machine.
Brother HL-5240L - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
9.8 kg
United Kingdom
Media Size Class
A4
Max Media Size
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
69.9 mm x 116 mm
Max Media Size (Custom)
216 mm x 406.4 mm
Print Speed
Up to 24 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Image Enhancement Technology
Brother HQ1200
Parallel, USB
266 MHz
RAM Installed (Max)
16 MB (528 MB) DIMM 144-pin
Language Simulation
PostScript 3, PCL 6, IBM ProPrinter XL, EPSON FX-850
Barcodes
Code 39, UCC/EAN-128, ISBN, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, FIM
Media Type
Envelopes, transparencies, labels, plain paper, bond paper, recycled paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Microsoft Windows 95, Microsoft Windows 98, Microsoft Windows NT 4.0, Linux, Microsoft Windows 2000, Microsoft Windows 2000 Professional, Microsoft Windows Millennium Edition, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Apple MacOS X 10.2.4 or later, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Apple MacOS 9.1 - 9.2
Microsoft Certification
Compatible with Windows 7
1-year warranty
37.1 cm x 38.3 cm x 24.6 cm
Printer Type
Workgroup printer - laser - monochrome
United Kingdom
Printer
Print Speed
Wired
Parallel, USB
1200 dpi
Brother HQ1200
PostScript Support
Standard
First Print Out Time B/W
8.5 sec
Language Simulation
Fonts Included
66 x PostScript 3 , 66 x PCL 6 , 12 x bitmapped , 11 x barcode
Barcodes
Media Handling
266 MHz
RAM
RAM Installed (Max)
16 MB / 528 MB (max)
Technology / Form Factor
DIMM 144-pin
Slots Qty
1
Empty Slots
1
Media Handling
Media Type
Media Size Class
A4
Max Media Size
69.9 mm x 116 mm
216 mm x 406.4 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Weight
60 g/m² - 161 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 161 g/m²
Max Media Capacity
800 sheets
Output Trays Capacity
150 sheets
1 x parallel - 36 PIN Centronics , 1 x USB 2.0 - 4 pin USB Type B
Power supply - internal
460 Watt
Power Consumption Stand by / Sleep
75 Watt
Software Included
Drivers & Utilities
Limited warranty - 1 year - on-site
Sound Emission (Idle)
30 dB
Sound Emission (Operating)
50 dB
37.1 cm
38.3 cm
24.6 cm
9.8 kg
Ink (3)
50MN Brother TN-3130 Toner Cartridge In Stock £70.49
50MN Brother TN-3170 Toner In Stock £92.93
50MN Brother DR-3100 Drum In Stock £144.41
Other bundles (1)
50MN Brother Support Pack 20 In Stock £71.89
Resources
The following resources are available for the Brother HL 5240L - printer - B/W - laser
