Brother DCP 7070DW Mono Laser Multifunction Printer
Quicklinx: 80H3WS00 Mfr#: DCP7070DWZU1
Make your working day more productive with the help of the DCP-7070DW.
Easily meet tight deadlines with printing speeds of up to 26ppm and duplex printing functionality.  Connect to your existing wireless or wired network, plus save money and energy with an optional high-yield toner cartridge and toner save mode. And stand out from the crowd with consistently high quality prints, scans and copies.
When you need to get through your workload fast, the DCP-7070DW is a hardworking office partner that won't let you down.
Brother DCP-7070DW - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Printing Technology
Laser (monochrome)
Recommended Monthly Volume
250 - 2000 pages
Max Copying Speed
Up to 26 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 26 ppm
Max Printing Resolution
Up to 2400 x 600 dpi
Scanning
600 x 2400 dpi
Original Size
A4 (210 x 297 mm) (max)
Media Size
76.2 x 116 mm (min) - 220 x 406.4 mm (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi
Office Machine Features
Scan to e-mail
AC 230 V (50/60Hz)
40.5 cm x 39.9 cm x 26.8 cm
10.3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Printing Technology
Laser - monochrome
250 - 2000 pages
Display
2 lines x 16 characters
USB 2.0, LAN, Wi-Fi
Scan to e-mail
Standard Memory
32 MB 32 MB
Copying
Max Copying Speed
Up to 26 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Sort
Printing
Max Printing Speed
Up to 26 ppm
Printer Drivers / Emulations
PCL 6
Image Enhancement Technology
Brother HQ1200
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Optical Resolution
600 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Min Media Size
76.2 x 116 mm
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm)
250 sheets
1 sheet
100 sheets
Input tray - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 26 ppm - B/W , Copying: up to 26 ppm - B/W
1 x USB 2.0 , 1 x LAN
Network Protocols
IPP, LPR/LPD, RAW IP (Port 9100), SNMP, HTTP, FTP, SMTP
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
Linux, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows 2000 Professional, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), Apple Mac OS X 10.4.11 or later, MS Windows Server 2008, MS Windows Server 2008 R2
AC 230 V (50/60Hz)
445 Watt
Power Consumption Standby
55 Watt
Power Consumption Sleep
1 Watt
Warm-Up Time
7 sec
First Copy Out Time B/W
11 sec
Consumables Included
1 x toner cartridge (black)
ENERGY STAR Certified
Limited warranty - 1 year , Technical support - lifetime
40.5 cm
39.9 cm
26.8 cm
10.3 kg
Shipping Width
52.7 cm
Shipping Depth
51 cm
Shipping Height
44 cm
Shipping Weight
13.4 kg
Sound Emission
30 dBA (idle) / 53 dBA (operating)
80H3 Brother TN2220 - Toner cartridge - 1 - 2600 pages In Stock £51.61
80H3 Brother BRO DR2200 DRUM HL2240/2240D/ In Stock £57.42
80H3 Brother TN2210 - Toner cartridge - 1 - 1200 pages In Stock £33.40
