The stylish DCP-1510 is a neat, all-in-one solution for the home office.
Fast and durable, it allows you to print, scan and copy effortlessly from one compact machine with always impressive results.
Quick and easy to install, this hardworking, multifunction printer has an impressive range of features, including special anti-jam technology. It prints at high speeds of up to 20ppm too so you can expect your first page in less than 10 seconds.
All in all, the DCP-1510 makes black and white printing easy – always delivering professional documents and a professional performance.
- Brother DCP-1510 - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 9000 pages
- Recommended Monthly Volume
- 1800 pages
- Max Copying Speed
- Up to 20 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 20 ppm
- Max Printing Resolution
- Up to 2400 x 600 dpi
- Scanning
- 600 x 1200 dpi
- Original Size
- 215.9 x 300 mm (max)
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, recycled paper
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 50 sheets
- Connection Availability
- Interface
- USB 2.0
- Power
- AC 230 V (50/60Hz)
- 38.5 cm x 255 cm x 34 cm
- 7 kg
- Microsoft Certification
- Compatible with Windows 7
- Laser - monochrome
- 9000 pages
- 1800 pages
- Display
- 2 lines x 16 characters
- Interface
- USB 2.0
- Standard Memory
- 16 MB
Copying
- Max Copying Speed
- Up to 20 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1
Printing
- Up to 20 ppm
- Printer Drivers / Emulations
- Windows GDI driver
- Image Enhancement Technology
- Brother HQ1200
- First Print Out Time B/W
- 10 sec
Scanning
- Optical Resolution
- 600 x 1200 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 215.9 x 300 mm
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 105 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), Folio (216 x 330 mm)
- 150 sheets
- 50 sheets
- Input tray - 150 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 105 g/m² , Output tray - 50 sheets
- Speed Details
- Printing: up to 20 ppm (A4) - B/W , Copying: up to 20 ppm - B/W
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- Linux, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, Apple Mac OS X 10.7.x, Apple Mac OS X 10.8.x, Windows 8, Apple Mac OS X 10.6.8
- Voltage Required
- 380 Watt
- Power Consumption Standby
- 40 Watt
- Power Consumption Sleep
- 0.8 Watt
- First Copy Out Time B/W
- 16 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages - Brother TN1050 , 1 x drum - up to 10000 pages - Brother DR1050
- 38.5 cm
- 255 cm
- 34 cm
- 7 kg
- Shipping Width
- 50.5 cm
- Shipping Depth
- 45.8 cm
- Shipping Height
- 43.6 cm
- Shipping Weight
- 8.9 kg
- Sound Emission
- 51 dBA (operating)
- 10 °C
- 32.5 °C
- 20 - 80% (non-condensing)
