511 Chassis: New Micro ATX Tower chassis for system building meeting the latest thermal requirements for dual core cpu's
- Piano finish
- 500w 12cm Fan PSU
- USB 3.0
- Screwless chassis with clip and lock design
- 1 x Steathed DVD cover ; 1 x 3.5"
- USB 3.0 x 1 , USB 2.0 x 1 , HD Audio to front panel
- Vented for dual core systems to side
- Excellent heat dissipation capabilities
- Riveted SECC metal frame
- ABS Plastic Front panel
- Removable side panel with grips for easy removal and maintenance
- Side Panels with filter for best ventilation
- Expansion Slots 4
- For Micro ATX boards
- Dimensions W180; D 390mm; H 365mm
- ROHS Compliant
- Power cable not included
Spec
- Manufacturer:OEM
- Audio Output: Yes - HD Audio
- I/O Ports: 1 x USB 3.0 , 1 x USB 2.0
- Colour: Black
- Weight: 5000g
- Form Factor: Micro ATX
- Supported Motherboard Form Factor: mATX
- Type: PC
- Material: SECC metal
- Ventilation Fans: 1 x 120mm fan space to front , 1 x 120mm rear fan space
- External Drive bays: 1 x 5.25
- Internal Drive bays : 1 x 3.5 , 2 x 3.5 HDD
