B-Tech Small Glass Shelf - Clear Glass
Quicklinx: BP5LWS00 Mfr#: BT7172/CG
This small glass shelf is designed to mount AV equipment such as DVD/Blu-ray players and games consoles to single-pole trolleys and floor stands.
B-TECH PRO Install BT7172 - mounting component
Mounting component - stand mountable, pole mount
Mounting Components
Shelf
35 cm x 30 cm x 1 cm
Recommended Use
AV System
Max Load Weight
7.5 kg
Material
Tempered glass
Clear glass
35 cm
30 cm
1 cm
Material
Tempered glass
Clear glass
AV Furniture
Mounting component
Mounting Components
Shelf
Recommended Use
AV System
Placing / Mounting
Stand mountable, pole mount
Max Load Weight
7.5 kg
