B-Tech 65" - 95" Heavy Duty Universal Flat Screen Wall Mount
Quicklinx: C3DCWS00 Mfr#: BT9903
Hurry, only 3 left in stock!
£136.73 ex VAT
£164.07 inc VAT
Wall mount for LCD / Plasma panel. Black Steel. Holds screens from 65".
B-TECH PRO Install BT9903 mounting kit - for flat panel - black
Mounting kit - wall-mountable
Mounting Components
Wall mount
115 cm x 3.1 cm x 77.3 cm
Recommended Use
Flat panel
Recommended Display Size
From 65"
Max Mounting Pattern Size
1100 x 730 mm
Max Load Weight
200 kg
Material
Steel
115 cm
3.1 cm
77.3 cm
Material
Steel
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
1100 x 730 mm
From 65"
Max Load Weight
200 kg
Hook-on installation
Brand: B-Tech
