B-Tech Truss Clamp Kit for 50mm Poles - Black
Quicklinx: CYWTWS00 Mfr#: BT7825/B
£85.23 ex VAT
£102.27 inc VAT
  • Adjustable adaptor for attaching 50mm poles to truss systems, scaffolding and other horizontal poles;
  • Cable management;
  • Supplied with safety bolt for secure installation;
  • Fits truss size from 42mm (1.7") – 50mm (2");
  • Zinc plated clamp;
  • POLE SOLD SEPARATELY.
  • Robust design
    Designed to support devices up to 140 kg, this mounting component ensures a secure and stable setup for your AV equipment.
  • Versatile compatibility
    The B-TECH System 2 BT7825 is engineered to accommodate a wide range of AV furniture, making it a practical choice for various setups and configurations.
B-TECH System 2 BT7825 mounting component - black
Mounting component
Mounting Components
Truss clamp
Max Load Weight
140 kg
Image Colour Disclaimer
The displayed product image may be a different colour
AV Furniture
Mounting component
Mounting Components
Truss clamp
Cable Management
Cable Management System (CMS)
Max Load Weight
140 kg
Brand: B-Tech
