B-Tech Hook on Plasma Mount 860mm - Black
Quicklinx: B69MWS00 Mfr#: BT8422-PRO/B
£50.09 ex VAT
£60.10 inc VAT
Marketing description is not available.
B-TECH Universal BT8422-PRO mounting kit - for flat panel - black
Mounting kit - wall-mountable
Mounting Components
Wall mount
3 cm
Recommended Use
Flat panel
Recommended Display Size
Up to 80"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 800 x 500 mm, 400 x 400 mm, 800 x 400 mm, 600 x 400 mm, 300 x 200 mm, 200 x 100 mm
Max Mounting Pattern Size
825 x 500 mm
Max Load Weight
70 kg
3 cm
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
825 x 500 mm
Up to 80"
Max Load Weight
70 kg
Lockable, low profile, hook-on installation
Brand: B-Tech
