B-Tech Ultra-Slim Flat Screen Wall Mount With Twin Cantilever Arms
Quicklinx: CQXFWS00 Mfr#: BT8225/B
Designed to mount medium to large sized screens, this ultra-slim twin cantilever arm wall mount features full motion technology with a tilting interface and three swivel points, allowing quick and easy repositioning of screens as required. Cover plates to hide fixings and integrated cable management help make this a neat and tidy mounting solution which is ideal for commercial applications as well as home installations.
  • Ultraslim design
    The B-TECH Mountlogic BT8225 boasts an ultraslim design, ensuring it blends seamlessly with your living space while providing robust support for your flat panel.
  • Versatile viewing angles
    With a full motion wall mount featuring dual cantilever arms, the BT8225 allows for a wide range of viewing angles. Pan up to 130° and tilt from -15° to 15°, ensuring optimal viewing pleasure from anywhere in the room.
  • Integrated cable management
    Keep your viewing area tidy with integrated cable management. This feature helps conceal cables, maintaining a clean and organized look around your flat panel display.
B-TECH Mountlogic BT8225 mounting kit - Ultra-Slim - for flat panel - black
Mounting kit (Ultra-Slim)
Mounting Components
Dual cantilever arm, full motion wall mount
Adjustable Depth
4-46.9 cm
Tilt
-15° to 15°
Pan
130°
Recommended Use
Flat panel
Recommended Display Size
39"-75"
VESA Mounting Interface
Up to 600 x 400 mm
Max Load Weight
45 kg
Adjustable Depth
4-46.9 cm
AV Furniture
Mounting kit
Mounting Components
Design
Ultra-Slim
Recommended Use
Flat panel
Up to 600 x 400 mm
Cable Management
39"-75"
Tilt
-15° to 15°
Pan
130°
Max Load Weight
45 kg
