- 360° pan with Auto-flip
- 12x optical zoom
- HDTV 720p resolution
- Outdoor-ready: IP66- and NEMA 4X-rated protection against dust, rain and snow
- Easy installation including Power over Ethernet (IEEE 802.3af)
The outdoor-ready AXIS P5514-E PTZ Dome Network Camera is a compact and affordably priced day and night pan/tilt/zoom camera. It is suitable for surveillance applications in areas such as parking lots, construction sites and business premises.
Pan/tilt/zoom capabilities
The PTZ camera enables users at a remote location to pan 360° for overview surveillance, tilt 180° and zoom in 12x with autofocus for detailed views. The Advanced Gatekeeper functionality enables the camera to automatically move to a preset position when motion is detected in a pre-defined area.
High video quality
Thanks to the camera's day/night functionality, high image quality is maintained even in low-light conditions. AXIS P5514-E provides H.264 and Motion JPEG streams in up to 720p resolution at 25/30 fps frame rate. H.264 greatly optimizes bandwidth and storage without compromising image quality.
Easy and reliable installation
AXIS P5514-E supports standard Power over Ethernet for easy installation. The camera simply connects either to a PoE-enabled switch or via a PoE midspan to a switch with one network cable for carrying power, video/audio and PTZ controls.
The camera also has IP66 and NEMA 4X ratings, which ensure protection against dust, rain, snow, ice and corrosion. It can operate in temperatures from -20 °C to 50 °F (-4 °F to 122 °F).
- AXIS P5514-E PTZ Dome Network Camera 50Hz - network surveillance camera
- Network surveillance camera - pan / tilt / zoom - outdoor - dust / vandal / waterproof
- Audio
- Yes: two-way audio capability
- Camera Mount Type
- Wall mount, ceiling mount
- 1.3 kg
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 12 x
- Max Resolution
- 1280 x 720
- Frame Rate (max)
- 60 frames per second
- Motion Detection
- Video Modes
- 720p
- Optical Sensor Type
- CMOS - 1/2.3"
- Minimum Illumination
- 0.7 lux - colour - F1.4 - 30 IRE , 0.08 lux - B&W - F1.4 - 30 IRE
- Focal Length
- 3.8 mm - 42.9 mm
- Focus Adjustment
- Automatic
- Lens Iris
- F/1.4-2.1 - auto iris
- Panning Range (degree)
- 360
- Tilting Range (degree)
- 180
- Ethernet 10Base-T/100Base-TX
- Voltage
- DC 20 - 28 V / AC 20 - 24 V / PoE Plus
- Backlight Compensation (BLC), sharpness control, white balance, brightness control, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, infrared cut filter, Video Motion Detection Technology, password protection, 100 preset positions, e-Flip, Audio Detection
- 3-year warranty
- Environmental Parameters (operating)
- 0 °C - 50 °C; 10 - 85% (non-condensing) relative humidity
- Audio Support
- Camera Mount Type
- Wired
- 1.3 kg
Camera
- Colour - Day&Night - pan / tilt / zoom - outdoor - dust / vandal / waterproof
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 720
- Motion Detection
- Video Modes
- 720p
- Digital Zoom
- 10
- Exposure Range
- 1/25 sec - 1/8000 sec
- Digital Video Capture Resolution
- 1280 x 720, 320 x 180
- Frame Rate (max)
- RAM
- 512 MB
- Flash Memory
- 256 MB
Image Sensor
- CMOS 1/2.3"
Lens Construction
- Optical Zoom
- 12 x
- Focal Length
- 3.8 mm - 42.9 mm
- Lens Iris
- F/1.4-2.1 auto iris
- Focus Adjustment
- Automatic
- Horizontal Field of View (degree)
- 5.2 - 59.2
Panning
- Range (degree)
- 360
- Speed (degree/sec)
- Up to 100
Tilting
- Range (degree)
- 180
- Up to 100
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSH, SSL, QOS, CIFS, SFTP
- Alarm Inputs Qty
- 1
- Alarm Outputs Qty
- 1
- Ports
- LAN - RJ-45
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Included Accessories
- Sunshield, mounting kit, connector kit
- C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, IEC 60529 IP66, EN 61000-6-1, FCC Part 15, ICES-003 Class A, NEMA Type 4X, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1, VCCI Class A, KN24, KCC KN22, IEC 60950-22, AS/NZS CISPR22:2004 Class A, EN 60950-22, UL 60950-22, EN 55022 Class A
- Power Requirements
- Power Device
- 12.95 Watt
- Limited warranty - 3 years
- 0 °C
- 50 °C
- Relative Humidity (operating)
- 10 - 85% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.67 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.82 |
