Axis A8105-E Network Video Door Station
Quicklinx: D5KGWS00 Mfr#: 0871-001
  • microSDHC Card
  • microSD Card
£690.02 ex VAT
£828.02 inc VAT
AXIS A8105-E Network Video Door Station is a full-fledged security camera, a powerful communication device, and a convenient door opener in one single device. A natural complement to your surveillance solution, it helps you secure your premises with reliable, around-the-clock identification.
  • Small and convenient
    AXIS A8105-E fits where you want it to go - on walls, doorframes and mullions. A flush mounting accessory enables recessed mounting in walls. AXIS A8105-E also features Axis' Digital Corridor Format, which makes it easy to adjust the viewing area to the location and increase the vertical area of view. Factory focus and support for PoE make installation fast and flexible, keeping costs low.
  • Keep your premises secure
    With AXIS A8105-E you get clear communication, high-quality video surveillance, and convenient remote entry control all in a single unit. You can see, talk to, identify, and then open the door to visitors directly or remotely from wherever you are. You can use your cell phone, IP phone or Video Management System (VMS) to do it.
    HDTV 1080p resolution and WDR - Forensic Capture deliver uncompromised visual identification even with strong backlighting - and LED lights provide enough light for you to see visitors at night. Axis' Zipstream technology significantly reduces bandwidth and storage requirements without compromising image quality. Acoustic echo cancellation and noise suppression make voices audible regardless of background noise thanks to uncompromised full duplex audio.
  • A powerful surveillance solution
    AXIS A8105-E doesn't just let you identify and control who enters your premises, it connects to your system just like any other surveillance camera and records what's happening outside your door. Integrated video analytics, such as AXIS Video Motion Detection, alert you of threatening events or vandalism so you can call for help - and you'll have a visual record of the incidents.
AXIS A8105-E Network Video Door Station - network surveillance camera
Network surveillance camera - fixed - outdoor - dustproof / waterproof
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
4.8 cm x 3.5 cm x 14.75 cm
280 g
White
Wired
Camera
Max Resolution
1920 x 1200
Frame Rate (max)
50 frames per second
Motion Detection
Optical Sensor Type
CMOS - 1/2.8"
Minimum Illumination
0 lux - infrared LEDs on , 1.96 lux - infrared LEDs off
Focal Length Control
Fixed focal
Focal Length
2.8 mm
Lens Iris
F/2.8
Voltage
DC 12 V / PoE
Sharpness control, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, contrast control, image mirror, Wide Dynamic Range (WDR), ONVIF support, Motion Detection Technology, Privacy Mask Function, echo reduction, full duplex audio, active tampering alarm, digital PTZ function, Text Caption Overlay, password protection, IR Corrected lens, Audio Detection, noise reduction, Zipstream technology
3-year warranty
Environmental Parameters (operating)
-25 °C - 55 °C
Audio Support
Wired
4.8 cm
3.5 cm
14.75 cm
280 g
Camera
Colour - fixed - outdoor - dustproof / waterproof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1920 x 1200
Motion Detection
Exposure Range
2 sec - 1/143000 sec
Video Capture
1920 x 1200 @ 50 fps , 1920 x 1200 @ 30 fps , 1920 x 1200 @ 25 fps , 1920 x 1200 @ 20 fps
RAM
256 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/2.8"
Lens Construction
Fixed focal
Focal Length
2.8 mm
Lens Iris
F/2.8
Horizontal Field of View (degree)
180
Vertical Field of View (degree)
120
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS, SNMP 2
Ports
LAN/power - RJ-45
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
EN55024, IEC 60529 IP65, EN 61000-6-1, ICES-003 Class A, EN 61000-6-2, NEMA Type 4, IEC 60068-2-27, IEC 60068-2-6, FCC Part 15 B Class A, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, EN 50581, AS/NZS CISPR 22, IEC 60950-22, EN 60950-22, UL 60950-22, UL 294
White
Power Requirements
DC 12 V / PoE
Software Included
Drivers & Utilities
Limited warranty - 3 years
-25 °C
55 °C
Brand: Axis
Price Range Ex VAT: £500 - £750
Stock Status: In stock
