Axis M3044-V Network Surveillance Camera
Quicklinx: CMMPWS00 Mfr#: 0802-001
  • microSD Card
  • microSDHC Card
£159.15 ex VAT
£190.98 inc VAT
AXIS M3044-V gives you sharp HDTV 720p video quality. The camera offers a horizontal field of view of 82°. And it comes with Wide Dynamic Range (WDR) technology for good detail even when light levels vary.
Axis' Zipstream technology reduces storage and bandwidth by up to 50%, while capturing important details in full image quality. Video streams can be encoded in H.264 and Motion JPEG. And for monitoring long, narrow areas, Axis' Corridor Format provides a portrait-shaped video stream. It maximizes image quality, while eliminating bandwidth and storage waste.
Small and compact, AXIS M3044-V can be mounted on walls or ceiling as you prefer. And you can easily repaint it to blend in with any environment. A black casing is also available as an accessory.
  • Axis quality at an affordable price
  • Sharp images, low bandwidth
  • Fits in your hand - fits in anywhere
  • Installation that's as easy as 1, 2, 3
    To keep implementation costs low, AXIS M3044-V is designed for fast and easy installation. No focusing is required because it comes factory focused. And with its 3-axis camera-angle adjustment, it can be easily leveled and directed in any direction. AXIS M3044-V is also vandal and dust resistant for optimal performance and minimal downtime.
AXIS M3044-V - network surveillance camera - dome
Network surveillance camera - fixed - dome - indoor - dustproof / waterproof / vandal-proof
10.1 cm x 10.1 cm x 5.6 cm
170 g
White
Wired
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
720p
Optical Sensor Type
CMOS - 1/3" - 1 MP
Minimum Illumination
0.25 lux F2.0 - 50 IRE
Focal Length Control
Fixed focal
Focal Length
2.8 mm
Lens Mounting
M12 mount
Lens Iris
F/2.0 - fixed iris
Panning Range (degree)
-177 to +177
Tilting Range (degree)
-76 to +76
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Backlight Compensation (BLC), sharpness control, white balance, progressive scanning, brightness control, contrast control, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, Privacy Mask Function, text stamp, Video Motion Detection Technology, active tampering alarm, password protection, Variable Bitrate (VBR), Zipstream technology
3-year warranty
Environmental Parameters (operating)
0 °C - 45 °C; 15 - 85% (non-condensing) relative humidity
Dome
Wired
10.1 cm
10.1 cm
5.6 cm
170 g
Camera
Colour - Day&Night - fixed - indoor - dustproof / waterproof / vandal-proof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Motion Detection
Video Modes
720p
Exposure Range
1/5 sec - 1/32500 sec
Digital Video Capture Resolution
1280 x 720, 320 x 240
Frame Rate (max)
RAM
512 MB
Flash Memory
256 MB
Image Sensor
1 MP CMOS 1/3"
Lens Construction
M12 mount - fixed focal
Focal Length
2.8 mm
Lens Iris
F/2.0 fixed iris
Horizontal Field of View (degree)
82
Vertical Field of View (degree)
44
Panning
Range (degree)
-177 to +177
Tilting
Range (degree)
-76 to +76
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSH, SSL, QOS, CIFS, SFTP
Ports
LAN/power - RJ-45
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
EN55024, ICES-003 Class B, EN 61000-6-1, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, IP42, IEC 62262 IK08, VCCI Class B, RCM, AS/NZS CISPR 22 Class B
White
Power Requirements
PoE
2.9 watt
Limited warranty - 3 years
45 °C
Relative Humidity (operating)
Brand: Axis
