Are you looking for an affordable and compact network camera that provides complete overview of your premises? From retail stores to small offices, AXIS M3048-P Network Camera is ideal for any location where high quality 360° video surveillance is required to help protect your assets.
Get the overview
AXIS M3048-P delivers outstanding 360° panoramic overview of smaller premises with a single camera. With its 12 MP sensor and full frame rate (up to 30 fps), it gives you complete and sharp overview, as well as allows you to zoom in to analyze live or recorded video footage. Whether an incident occurred in the middle of the space, or in a far corner, you can see distortion-free views of a specific area thanks to dewarping. -
Compact and discreet
A sleek, no-dome design means AXIS M3048-P is easily concealed from view. AXIS M3048-P is made from environment-friendly recycled plastics. The camera can also be repainted to blend in discreetly and seamlessly with your interior color scheme. -
Easy to install, affordable to run
Affordably priced AXIS M3048-P can be easily installed on walls or ceilings. It can also be mounted on a pendant or installed recessed. The camera is delivered factory-focused out of the box, so no focusing is required. And total costs are further reduced by Axis Zipstream technology, which preserves important details in full image quality, while reducing storage and bandwidth by up to 50%.
- AXIS M3048-P - network surveillance camera - dome
- Network surveillance camera - fixed - dome
- 10.1 cm x 10.1 cm x 4.6 cm
- 240 g
- White
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 2880 x 2880
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS - 1/1.7" - 12 MP
- Minimum Illumination
- 0.35 lux F2.8 - 50 IRE
- Focal Length Control
- Fixed focal
- Focal Length
- 1.65 mm
- Lens Iris
- F/2.8 - fixed iris
- Panning Range (degree)
- -180 to +180
- HDMI, Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Sharpness control, white balance, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, Video Motion Detection Technology, active tampering alarm, digital PTZ function, 360° monitoring, Variable Bitrate (VBR), video analytics, Zipstream technology, Pixel Counter Support, digest authentication
- 3-year warranty
- Environmental Parameters (operating)
- 0 °C - 40 °C; 10 - 85% (non-condensing) relative humidity
- Form Factor
- Dome
- Wired
- 10.1 cm
- 10.1 cm
- 4.6 cm
- 240 g
Camera
- Colour - fixed
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 2880 x 2880
- Motion Detection
- Exposure Range
- 1/2 sec - 1/25000 sec
- Digital Video Capture Resolution
- 640 x 240, 1920 x 1440, 480 x 480, 640 x 360, 2048 x 1152, 480 x 360, 2560 x 1440, 2880 x 2880, 2560 x 720, 1920 x 720
- Frame Rate (max)
- RAM
- 1024 MB
- Flash Memory
- 256 MB
Image Sensor
- 12 MP CMOS 1/1.7"
Lens Construction
- Fixed focal
- Focal Length
- 1.65 mm
- Lens Iris
- F/2.8 fixed iris
- Horizontal Field of View (degree)
- 185
- Vertical Field of View (degree)
- 185
Panning
- Range (degree)
- -180 to +180
- Video
- HDMI
- Network Interface
- Ethernet 10Base-T/100Base-TX
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSH, SSL, QOS, CIFS, SFTP
- Ports
- LAN/power - RJ-45 , HDMI
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- CISPR 22 Class A, EN55024, EN 61000-6-1, ICES-003 Class A, EN 61000-6-2, IEC 60068-2-27, IEC 60068-2-6, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78, VCCI Class A, KN35, EN 62368-1, EN 55032 Class A, KCC KN32 Class A
- White
- Power Requirements
- PoE
- Power Device
- 5.6 Watt
- Limited warranty - 3 years
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 10 - 85% (non-condensing)
