Axis P3719-PLE Panoramic Dome Camera
Quicklinx: FXBSWS00 Mfr#: 01500-001
  • microSDHC Card
  • microSD Card
AXIS P3719-PLE has been designed to capture images with exceptional clarity and sharpness irrespective of lighting conditions, thanks to WDR and 360° IR illumination. The incorporation of four varifocal camera heads allows the camera to easily monitor four different areas in various directions. It provides excellent 360° overviews or a combination of overviews and detailed close-ups.
  • Wide environmental adaptability
    Designed to operate in extreme conditions, the AXIS P3719-PLE camera functions flawlessly within a temperature range of -30°C to 50°C and a humidity range of 10 - 100%, ensuring reliable surveillance in challenging weather.
  • Versatile storage options
    Supports a variety of memory cards including microSD, microSDHC, and microSDXC, providing flexible storage solutions that meet the demands of modern surveillance systems.
  • Comprehensive field of view
    Equipped with a vari-focal lens and motorized focus adjustment, this camera offers an angular field of view ranging from 29° to 116°, ensuring wide area coverage and detailed images.
  • Robust networking capabilities
    Features a rich set of network protocols including IPv4, IPv6, DHCP, and more, facilitating seamless integration into existing network infrastructures and ensuring reliable data transmission.
  • Advanced imaging technology
    Boasts a 4CMOS optical sensor and a total of 15,000,000 pixels, coupled with Forensic WDR, Zipstream technology, and infrared capabilities, delivering high-quality images even in low-light conditions.
AXIS P3719-PLE - panoramic camera - dome
Panoramic camera - fixed - dome
25.5 cm x 25.5 cm x 9.15 cm
2 kg
Wired
Camera
Colour - Day&Night
Optical Zoom
2 x
Max Resolution
2560 x 1440
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1440p
Optical Sensor Type
4CMOS - 4 x 1/2.5" - 15 MP
Minimum Illumination
0.2 lux - colour - F1.8 - 50 IRE , 0.04 lux - B&W - F1.8 - 50 IRE , 0 lux - IR
Focal Length Control
Vari-focal
Focal Length
3 mm - 6 mm
Focus Adjustment
Motorised
Lens Iris
F/1.8-2.6
Panning Range (degree)
-90 to +90
Tilting Range (degree)
-25 to +95
Ethernet 10Base-T/100Base-TX
Voltage
PoE Plus Class 4
Sharpness control, white balance, saturation control, brightness control, contrast control, Privacy Mask Function, Video Motion Detection Technology, Event Notification, Zipstream technology, ONVIF (Profile S) support, ONVIF (Profile G) support, image overlay, exposure control, infrared-cut filter, Forensic WDR, exposure zone
3-year warranty
Environmental Parameters (operating)
-30 °C - 50 °C; 10 - 100% relative humidity
Panoramic camera
Dome
Wired
25.5 cm
25.5 cm
9.15 cm
2 kg
Camera
Colour - Day&Night - fixed
Digital Video Format
MJPEG, H.264, MPEG-4 AVC
Max Digital Video Resolution
2560 x 1440
Motion Detection
Video Modes
1440p
Exposure Range
1/5 sec - 1/66500 sec
Infrared LEDs
Infrared Distance
15 m
Video Capture
2560 x 1440 @ 60 fps
RAM
1 GB
Flash Memory
512 MB
Image Sensor
15 MP 4CMOS 4 x 1/2.5"
Lens Construction
Vari-focal
Optical Zoom
2 x
Focal Length
3 mm - 6 mm
Lens Iris
F/1.8-2.6
Focus Adjustment
Motorised
Horizontal Field of View (degree)
49 - 101
Vertical Field of View (degree)
29 - 54
Diagonal Field of View (degree)
58 - 116
Panning
Range (degree)
-90 to +90
Tilting
Range (degree)
-25 to +95
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSH, SSL, QOS, CIFS, SFTP
Ports
LAN/power - RJ-45
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Screw bit T20, mounting tool
EN 61000-3-2, EN 61000-3-3, EN55024, EN 61000-6-1, ICES-003 Class A, EN 61000-6-2, IEC 60068-2-27, IEC 60068-2-6, IP67, FCC Part 15 B Class A, IP66, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78, EN 50121-4, IEC 62236-4, VCCI Class A, RCM, IK09, IEC 62471, IEC EN60529, NEMA250 Type 4X, AS/NZS CISPR 32 Class A, EN 55032 Class A, KCC KN32 Class A, IEC/EN/UL 60950-22, IEEE 802.3at, KCC KN35, IEC/EN 62262, IEC/EN/UL 62368-1, IEEE 802.1x, NIST SP500-267
Power Requirements
PoE Plus Class 4
25.5 Watt
Software Included
Windows decoder 1-user licence
Limited warranty - 3 years
-30 °C
50 °C
Relative Humidity (operating)
10 - 100%
