Axis P3346 Network Camera - Network camera - dome - tamper-proof
Quicklinx: 91RJWS00 Mfr#: 0369-001
The AXIS P3346 is a 3-megapixel day and night fixed dome network camera that offers superb video performance. It delivers full frame rate HDTV 1080p (1920 x 1080) in compliance with the SMPTE 274M standard in resolution, color representation, 16:9 aspect ratio and frame rate. Multiple H.264 streams, as well as Motion JPEG streams, can be provided simultaneously. The camera also supports digital pan/tilt/zoom and multi-view streaming, where the full view and several areas cropped from the full view can be streamed simultaneously. The remote zoom adjusts the angle of view over the network and the remote focus eliminates the need for manual focusing.
  • High-performance video
  • Advanced iris control
    AXIS P3346 also features P-Iris, a new and revolutionary precise iris control system that provides optimal image quality in all lighting conditions. It provides images with better contrast, clarity, resolution and depth of field. Having good depth of field - where objects at different distances from the camera are in focus simultaneously - is important in the video monitoring of, for example, a long corridor or parking lot. It also features wide dynamic range and day/night functionality enable clear images both in daylight and in dark lighting conditions.
  • Tamper-resistant casing
    AXIS P3346 with its tamper-resistant casing, is a fixed dome specifically designed for indoor environments where discreet and compact solutions are required. It is the perfect solution for video surveillance in areas such as retail stores, governmental buildings and airports.
AXIS P3346 Network Camera - network surveillance camera - dome
Network surveillance camera - fixed - dome - tamper-proof
Audio
Yes: two-way audio capability, built-in microphone
14.8 cm x 14.8 cm x 10.1 cm
490 g
Wired
Camera
Colour - Day&Night
Optical Zoom
3 x
Max Resolution
2048 x 1536
Optical Sensor Type
CMOS - 1/3"
Minimum Illumination
0.5 lux - colour - F1.2 , 0.08 lux - B&W - F1.2
Focal Length Control
Vari-focal
Focal Length
3 mm - 9 mm
Lens Iris
F/1.2 - auto iris (video)
Panning Range (degree)
360
Tilting Range (degree)
360
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Motion sensor, Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), SDHC-card slot, infrared cut filter, P-Iris control
3-year warranty
Environmental Parameters (operating)
0 °C - 50 °C; 15 - 85% (non-condensing) relative humidity
Audio Support
Dome
Wired
14.8 cm
14.8 cm
10.1 cm
490 g
Camera
Colour - Day&Night - fixed - tamper-proof
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
2048 x 1536
Exposure Range
1/35500 sec - 1/6 sec
Video Capture
2048 x 1536 @ 20 fps , 1920 x 1080 @ 30 fps , 1600 x 1200 @ 30 fps
RAM
256 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/3"
Lens Construction
Vari-focal
Optical Zoom
3 x
Focal Length
3 mm - 9 mm
Lens Iris
F/1.2 auto iris (video)
Horizontal Field of View (degree)
30 - 84
Vertical Field of View (degree)
22 - 63
Panning
Range (degree)
360
Tilting
Range (degree)
360
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, IGMP
Alarm Inputs Qty
1
Alarm Outputs Qty
1
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - line-in/microphone - mini-phone 3.5 mm , 1 x audio - line-out - mini-phone 3.5 mm
Mounting bracket, smoked dome cover
C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, EN 60950-1
Power Requirements
PoE
Software Included
Drivers & Utilities
Limited warranty - 3 years
50 °C
Relative Humidity (operating)
