The palm-sized AXIS Companion Dome V is an indoor fixed dome that features high quality video in HDTV 1080p / 2 MP resolution and WDR. The camera features PoE and a built-in microSD card slot for edge storage. The support for Axis' Zipstream technology ensures maximized recording time. The HDMI output can be used for direct connection to public view monitors. The vandal and dust-resistant camera can be mounted on walls or ceilings.
- AXIS Companion Dome V - network surveillance camera
- Network surveillance camera - fixed dome - dustproof / vandal-proof
- 10.1 cm x 10.1 cm x 5.6 cm
- 170 g
- White
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- CMOS - 1/3" - 2 MP
- Minimum Illumination
- 0.25 lux F2.0 - 50 IRE
- Focal Length Control
- Fixed focal
- Focal Length
- 2.8 mm
- Lens Mounting
- M12 mount
- Lens Iris
- F/2.0 - fixed iris
- Panning Range (degree)
- -177 to +177
- Tilting Range (degree)
- -69 to +69
- HDMI, Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Backlight compensation, sharpness control, white balance, progressive scanning, brightness control, contrast control, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), Privacy Mask Function, text stamp, Video Motion Detection Technology, active tampering alarm, digital PTZ function, password protection, Variable Bitrate (VBR), Zipstream technology
- 3-year warranty
- Environmental Parameters (operating)
- 0 °C - 45 °C; 15 - 85% (non-condensing) relative humidity
- Wired
- 10.1 cm
- 10.1 cm
- 5.6 cm
- 170 g
Camera
- Colour - fixed dome - dustproof / vandal-proof
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Exposure Range
- 1/5 sec - 1/32500 sec
- Digital Video Capture Resolution
- 1280 x 720, 320 x 240, 1920 x 1080
- Frame Rate (max)
- RAM
- 512 MB
- Flash Memory
- 256 MB
Image Sensor
- 2 MP CMOS 1/3"
Lens Construction
- M12 mount - fixed focal
- Focal Length
- 2.8 mm
- Lens Iris
- F/2.0 fixed iris
- Horizontal Field of View (degree)
- 106
- Vertical Field of View (degree)
- 57
Panning
- Range (degree)
- -177 to +177
Tilting
- Range (degree)
- -69 to +69
- Video
- HDMI
- Network Interface
- Ethernet 10Base-T/100Base-TX
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSH, SSL, QOS, CIFS, SFTP
- Ports
- LAN/power - RJ-45 , HDMI
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- EN55024, ICES-003 Class B, EN 61000-6-1, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, IP42, IEC 62262 IK08, VCCI Class B, RCM, AS/NZS CISPR 22 Class B
- White
- Power Requirements
- PoE
- Power Device
- 3 Watt
- Limited warranty - 3 years
- 0 °C
- 45 °C
- Relative Humidity (operating)
- 15 - 85% (non-condensing)
