APC Smart-UPS SC is the perfect protection for the IT resources of your growing business. Manageable and cost effective, APC Smart-UPS SC is designed for use by small and medium companies looking to protect networking equipment, providing both power and data-line protection. Included PowerChute Business Edition management software allows you to configure safe system shutdowns and take advantage of advanced UPS management features like automated risk assessments and runtime capacity calculations. (All major operating systems supported). Communications are through your server's standard serial port. When you are ready to take your business to the next level you can use the same software environment found on Smart-UPS SC to seamlessly manage other Smart-UPS models, allowing you to grow your IT infrastructure without having to replace your software or retrain your administrators. Built on the same standards as the award winning Smart-UPS UPS, the Smart-UPS SC is the UPS to start your business with.
- APC Smart-UPS SC 1500VA - UPS - 865 Watt - 1500 VA
- UPS - external
- Rack Size
- 2U
- 21.4 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 5%
- Power Capacity
- 865 Watt / 1500 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 4 x power IEC 60320 C13
- Battery
- Lead Acid
- Battery Form Factor
- Internal
- Run Time (Up To)
- 7.6 min at full load
- Grey
- 43.2 cm x 46.3 cm x 8.9 cm
- 2-year warranty
- UPS - external
- Battery Enclosure Type
- Internal
- Height (Rack Units)
- 2U
- Grey
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 175 - 295 V
- Input Voltage Range (Adjustable)
- AC 160 - 286 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 5% - 50/60 Hz
- Power Capacity
- Dataline Surge Protection
- Network - RJ-45
- Output Waveform
- Stepped approximation to a sinewave
- Surge Suppression
- Surge Response Time
- 0 ns
- Surge Energy Rating
- 445 Joules
- Circuit Protection
- Circuit breaker
- Technology
- Lead Acid
- Run Time (Up To)
- Recharge Time
- 8 hours
- 1 x management (RS-232) - 9 pin D-Sub (DB-9)
- Cables Included
- Serial cable - external , Power cable 1.8 m
- Rack Mounting Kit
- Included
- Audible alarm, Automatic Voltage Regulation (AVR), LED indicators
- C-Tick, GOST, UL 1449, VDE
- Software Included
- Drivers & Utilities
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 45 dBA
- 43.2 cm
- 46.3 cm
- 8.9 cm
- 21.4 kg
APC Replacement Battery Cartridge #59 | In Stock | £150.35 |
Resources
The following resources are available for the APC Smart-UPS SC 1500VA - UPS - 865 Watt - 1500 VA
Customer reviews
Write a review for the APC Smart-UPS SC 1500VA - UPS - 865 Watt - 1500 VA here!
Not suitable for normal servers
Reviewed by Pete Smith. Review Posted 22/12/2008
I recently had one of these units fail within 1 week. It was connected to a server which was not particularly power hungry. APC refused to have anything to do with it because they say the unit is not suitable for servers that use more than 150W. This information is not evident in any of the documentation, so beware.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
