Adjustable voltage sensitivity
Provides the ability to adapt the UPS for optimal performance in specific power environments or generator applications. -
Audible alarms
Provides notification of changing utility power and UPS power conditions -
Automatic self-test
Periodic battery self-test ensures early detection of a battery that needs to be replaced. -
Battery charging indicator
Lets you know when your battery is charging and when it is fully charged. -
Battery failure notification
Provides early-warning fault analysis on batteries enabling timely preventive maintenance -
Building Wiring Fault Indicator
This LED informs users of potentially dangerous wiring problems in the wall circuit. -
Cold-start capable
Provides temporary battery power when the utility power is out. -
Dataline surge protection
Provides protection of connected equipment from power surges on the data lines. -
Disconnected battery notification
Warns when a battery is not available to provide backup power. -
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced -
Safety-agency approved
Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment. -
Simple battery replacement
Increases UPS availability by allowing quick, easy battery replacement. -
USB charging ports
Simultaneously charge mobile devices, including smartphones and tablets. -
USB connection
Use your PC to access additional power protection and management features for your UPS via a USB Port. -
User-replaceable batteries
Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
- APC Back-UPS BE850G2 - UPS - 520 watt - 850 VA
- UPS - external
- 4.5 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Power Capacity
- 520 watt / 850 VA
- Input Connectors
- 1 x power BS 1363A
- Output connectors
- 6 x power (UPS and surge) , 2 x power (surge) , 1 x 4 pin USB Type A 2.4 A , 1 x 24 pin USB-C
- Battery
- Lead Acid
- Batteries Qty
- 1
- Black
- 13 cm x 36.5 cm x 12 cm
- 3-year warranty
- UPS - external
- Black
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Frequency Required
- 47 - 63 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V
- Power Capacity
- 520 watt / 850 VA
- Dataline Surge Protection
- Network - RJ-45
- Output Waveform
- Stepped approximation to a sinewave
- Surge Suppression
- Surge Energy Rating
- 310 joules
- Circuit Protection
- Circuit breaker
- Efficiency
- 80%
- Power Factor (PF)
- 0.612
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- 72 min at 50 Watts , 34.1 min at 100 Watts , 14.3 min at 200 Watts , 7.7 min at 300 Watts , 4.5 min at 400 Watts , 2.6 min at 500 Watts
- Cables Included
- Power cable 1.83 m
- Equipment Protection Value
- 100000 Euros
- Overload protection, LED indicators
- EAC
- Software Included
- APC PowerChute Personal Edition
- Limited warranty - 3 years
- 13 cm
- 36.5 cm
- 12 cm
- 4.5 kg
- Shipping Width
- 18.6 cm
- Shipping Depth
- 44.1 cm
- Shipping Height
- 19 cm
- Shipping Weight
- 5 kg
APC Replacement Battery Cartridge RBC17 | In Stock | £57.50 |
