Intuitive LCD interface provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
High frequency design reduces or eliminates bulky transformers resulting in lighter units for ease of handling.
APC Smart-UPS X 3000 Rack/Tower LCD recognizes when external battery packs are attached and automatically adjusts runtime.
Patent-pending operating mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
Cold-start capable
Provides temporary battery power when the utility power is out -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection -
High online efficiency
Reduces utility costs, generates less heat -
Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys -
Predictive replace battery date
Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning -
SmartSlot
Customize UPS capabilities with management cards -
Energy meter
Provides actual kilowatt hours of usage for energy conscious users -
Multiple switched outlet groups
Multiple outlet groups that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding
- APC Smart-UPS X 3000 Rack/Tower LCD - UPS - 2700 watt - 3000 VA - with APC UPS Network Management Card AP9631
- UPS - rack-mountable / external
- Rack Size
- 4U
- 38.64 kg
- Input Wiring
- 1-phase
- Input Voltage
- AC 208/230 V
- Output Voltage
- AC 208/230 V
- Power Capacity
- 2700 watt / 3000 VA
- Input Connectors
- 1 x power IEC 60320 C20
- Output connectors
- 8 x power IEC 60320 C13 , 2 x IEC jumper , 2 x power IEC 60320 C19
- Battery
- Lead Acid
- Batteries Qty
- 1
- Run Time (Up To)
- 6.3 min at full load
- Networking
- Ethernet 10/100, RS-232, USB
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2
- Black
- Pricing Type
- APC Take-Back
- Packaging Recycled Content
- Made of recycled cardboard
- 43.2 cm x 48.3 cm x 17.8 cm
- 3-year warranty
- Bundled with
- APC UPS Network Management Card AP9631
- Height (Rack Units)
- 4U
- Black
- Bundled with
- UPS Technology
- Line interactive
- Input Voltage
- AC 208/230 V
- Input Voltage Range
- AC 140 - 280 V
- Frequency Provided
- 47 - 63 Hz
- Input Wiring
- 1-phase
- Frequency Required
- 47 - 63 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 208/230 V 47 - 63 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 645 joules
- Circuit Protection
- Circuit breaker
- Efficiency
- 98.5%
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- 6.3 min at full load , 15.7 min at half load
- Recharge Time
- 3 hours
- Remote Management Interface
- 1 x USB , 1 x RS-232 , 1 x EPO (emergency power off) , 1 x management (Ethernet) - RJ-45
- Expansion Slots
- 1 (total) / 0 (free) x SmartSlot
- Cables Included
- Serial cable , USB cable , Power cable 1.83 m
- Rack Mounting Kit
- Included
- Audible alarm, LCD display, overload protection
- CSA, C-Tick, GOST, UL 1449, UL 1778, VDE, IEC 60950, EN 50091-2, IRAM, RoHS, EN 50091-1, FCC Part 15 A, REACH
- Pricing Type
- APC Take-Back
- Software Included
- APC PowerChute Business Edition
Sustainability Information
- Limited warranty - 3 years , Limited warranty - battery - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 55 dBA
- 43.2 cm
- 48.3 cm
- 17.8 cm
- 38.64 kg
- Shipping Width
- 58.6 cm
- Shipping Depth
- 63.3 cm
- Shipping Height
- 33 cm
- Shipping Weight
- 47.73 kg
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £30.51 |
APC Power Cord IEC 320 C19 TO IEC 320 C14 | In Stock | £50.04 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £205.78 |
APC 1U Vertical Cable Organiser | In Stock | £125.77 |
APC 1U Horizontal Cable Organiser | In Stock | £55.58 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £53.95 |
APC Pwr Cord, 16A, 200-240V, C19 to UK Plug | In Stock | £60.00 |
APC Netshelter heavy duty shelf | In Stock | £145.67 |
APC Rack PDU, Basic, Zero U, 10A,2 | In Stock | £279.09 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £304.83 |
APC 2-Post Mounting Kit for Smart-UPS | In Stock | £175.48 |
APC 3Yr Extended Warranty SP | In Stock | £322.47 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £328.60 |
APC Temperature and Humidity Sensor | In Stock | £130.54 |
APC POWER CORD C13 TO C20 1.98m Black | In Stock | £53.16 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £293.94 |
APC Cable Managers (Qty 10) | In Stock | £36.45 |
APC 2G Power distribution strip | In Stock | £655.45 |
APC Rack PDU 2G METERED ZEROU | In Stock | £702.13 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 | In Stock | £515.77 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £1,018.97 |
APC 19" Rack LCD Console | In Stock | £1,385.79 |
APC Power Cord Locking C19 to C20 3.0m | In Stock | £72.10 |
APC Vertical Cable Organizer, NetShelter SX, 42U | In Stock | £96.64 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £81.60 |
APC Power Cord Kit (6 ea) Locking C19 to C20 1.2m | In Stock | £151.89 |
APC Power Cord, C19 to CEE/7 Schuko, 2.5m | In Stock | £55.05 |
APC Switched Rack PDU 2G Zero U Power Distribution Unit | In Stock | £1,518.27 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £99.79 |
APC Smart-UPS X 120V External Battery Pack Rack/Tower | In Stock | £674.62 |
APC 1U Blanking Panel Kit | In Stock | £34.87 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £56.33 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £48.30 |
APC Power Cable (pack of 6) 1.22m | In Stock | £90.23 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £69.65 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £132.53 |
APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m | In Stock | £104.13 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £639.73 |
APC Replacement Battery Cartridge #143 | In Stock | £429.09 |
APC Metered Rack PDU | In Stock | £863.02 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £766.18 |
APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U | In Stock | £268.27 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,128.72 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £62.92 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £689.02 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,271.81 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £164.37 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 | In Stock | £1,309.18 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £83.54 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £467.09 |
