Akasa Newton Fanless Solid Aluminium Case for NUC System
Quicklinx: 8T7VWS00 Mfr#: AK-ITX07-BK
Newton Fanless case for NUC systems
  • Aluminium fanless CPU cooling design
  • Ideal for business, education and embedded environments
  • Form factor: UCFF 4" X 4"
  • Suitable for VESA mounting
  • Antenna fitting holes
  • Kensington lock
  • Compatible with the following NUC motherboard: Intel DCP847SK / Intel D33217GKE
Spec
  • Material Aluminium
  • Motherboards types UCFF 4" X 4"
  • Dimensions 150 x 150 x 47mm (W x D x H)
  • Weight 925 g
  • Antenna fitting holes 2
  • Security Kensington lock
  • VESA mounting Support
Akasa Newton - USFF - mini ITX
System cabinet
Ultra small form factor
I/O Connectors
1 x USB 2.0
Supported Motherboards
Mini-ITX
System Cabinet Features
VESA mounting interface, Kensington lock support, aerial fitting holes
No power supply
15 cm x 15 cm x 4.7 cm
925 g
Max Mainboard Size
Mini ITX
Mini-ITX
Product Material
Aluminium
1 x USB 2.0
Thumbscrews, thermal paste
No power supply
15 cm
15 cm
4.7 cm
925 g
