Akasa Euler Fanless Solid Aluminium Thin Mini-ITX Case
Quicklinx: 8DYNWS00 Mfr#: AK-ITX05-BK12UK
Euler Fanless Solid Aluminium Thin Mini-ITX Case: VESA Mountable with 120W external AC Adapter
  • Solid crafted aluminium case
  • Fanless CPU cooling design
  • Designed for thin mini-ITX motherboard
  • VESA mountable
  • Compatible with the following thin mini-ITX motherboard: Intel DQ77KB Ivy Bridge + Intel DH61AG Sandy Bridge
Specification
  • Material Aluminium with anodized black
  • Panel material Aluminium
  • Motherboards types Thin mini-ITX with DC onboard
  • Dimensions 228 x 187 x 61.5mm (WxDxH)
  • Weight 2200g
  • Internal bays 1 (for 2.5" HDD)
  • Compact design
    The ultra small form factor of the Akasa Euler is perfect for users looking to save space without sacrificing performance. Its sleek design allows for easy integration into any setting, from home offices to tight workstation cubicles.
  • Versatile mounting
    Equipped with a VESA mounting interface, this chassis offers flexible installation options. Mount it behind a monitor or on a wall to maximize your workspace and keep it clutter-free.
Akasa Euler - USFF - mini ITX
System cabinet
Ultra small form factor
Supported Motherboards
Mini-ITX
System Cabinet Features
No power supply
22.8 cm x 18.7 cm x 6.15 cm
2.2 kg
Max Mainboard Size
Mini ITX
Mini-ITX
SATA cable, cable ties
No power supply
22.8 cm
18.7 cm
6.15 cm
2.2 kg
