Building on the experience of the successful Enigma case Akasa has developed this high performance yet compact mini-ITX case. The sleek fascia panel makes it perfect for multimedia applications while optional security features like Kensington security slot, intrusion alarm facility and case locking tab makes it a perfect solution for both business and education environments.
The new slightly larger design incorporates a new bay layout providing improved airflow and easier cable routing, this makes the system build easier. Now compatible with all mini-ITX boards including embedded, AMD Socket AM3 and Intel LGA775,1156.
2 bays are included: 2.5" HDD and slimline optical drive. On the front panel are HD audio and two USB ports for easy connectivity.
Stylish and easy fit design, compatible with standard Vesa mount LCD monitors. Save space and be Secure!
- Designed for ultra compact systems
- Ideal for business and education environment
- Stylish design for multimedia applications
- Compatible with mini-ITX motherboards
- VESA mounting compatible (10mm)
- Akasa Crypto Vesa - SFF - mini ITX
- Product Type
- System cabinet
- Form Factor
- Small form factor
- Smooth black
- Localisation
- United Kingdom
- I/O Connectors
- 2 x USB 2.0 , 2 x audio
- Supported Motherboards
- Mini-ITX
- Power Device
- Power adapter 80 Watt (ATX12V)
- Motherboard Power Connectors
- 24-pin main power connector, 4-pin ATX12V connector
- 24.5 cm x 22.7 cm x 6.8 cm
- Form Factor
- Small form factor
- Max Mainboard Size
- Mini ITX
- Mini-ITX
- Internal Bays Qty
- 1
- Front Accessible Bays Qty
- 1
- Smooth black
- Localisation
- United Kingdom
- Expansion Bays
- 1 (total) / 1 (free) x front accessible - 5.25" Slim Line , 1 (total) / 1 (free) x internal - 2.5"
- 2 x USB 2.0 , 2 x audio - mini-jack
- Included Accessories
- SATA cable
- Power Device
- Power adapter
- Specification Compliance
- ATX12V
- Power Provided
- 80 Watt
- 24.5 cm
- 22.7 cm
- 6.8 cm
