The CORSAIR Carbide Series 275R is a compact mid-tower ATX case that matches minimalist design and a beautiful tempered glass window with a straightforward interior layout and versatile cooling options.
Minimalist design, maximum features
The CORSAIR Carbide Series 275R is a compact mid-tower ATX case that matches minimalist design and edge-to-edge window with a straightforward interior layout. -
Full window side panel
Edge-to-Edge full window side panel shows off your system in style. -
Clean and minimalist design
Clean lines, curved edges with soft accent lighting. -
Expansive storage space
Rugged-construction steel drive trays provide ample room for additional SSDs and hard drives. -
Built-in cable routing
Dedicated cable routing compartment enables effortlessly clean builds. -
Direct Airflow Path cooling
Two included CORSAIR SP120 fans ensure cool air is directed to the hottest components, without any interference from drive cages.
- CORSAIR Carbide Series 275R - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- Yes, acrylic
- Black
- I/O Connectors
- 2 x USB 3.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Front dust filter, cable management holes, meshed top, supports 240 mm radiator in top, PSU dust filters, supports 280/360 mm radiator in front panel
- Power Device
- No power supply (ATX)
- 21.1 cm x 45.5 cm x 46 cm
- 10.14 kg
- 2-year warranty
- Form Factor
- Tower
- Windowed Side Panel Material
- Acrylic
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 5
- Product Material
- Steel, acrylic
- Black
- Cooling System
- Front: 120 mm fan x 1 / 3 x 120 mm or 2 x 140 mm fan supported , Rear: 120 mm fan x 1 , Top: 120 mm fan mount x 2
- CPU Cooler Max Height
- 170 mm
- Video Card Max Length
- 370 mm
- Power Supply Max Length
- 180 mm
- Expansion Bays
- 2 (total) / 2 (free) x internal - 3.5" , 3 (total) / 3 (free) x internal - 2.5"
- Expansion Slots
- 7
- 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Included Accessories
- Accessory kit
- Power Device
- No power supply
- Specification Compliance
- ATX
- 21.1 cm
- 45.5 cm
- 46 cm
- 10.14 kg
- Limited warranty - 2 years
