The ZyXEL XGS3700 series are advanced Layer 2 Plus (Layer 3 Lite) Gigabit managed switches perfect for data center access, SMB core/aggregation, and mission critical PoE applications. The high redundancy hardware architecture includes dual, internal power supplies and hot-swappable fan and power modules. The PoE models also comply with the IEEE 802.3at PoE Plus standard and provide industry-leading PoE power budget of up to 1000 watts.
The ZyXEL XGS3700 series provides the flexibility to be deployed in all sorts of deployments including data center access, SMB core/aggregation, and mission critical PoE applications. The Series provides added routing flexibility with support for static routing and policy-based routing (PBR); and its full and consistent GUI, CLI and MIB ensures simplified management and consistent configurations.
Non-stop business continuity for mission critical applications
The ZyXEL XGS3700 series are advanced Layer 2 Plus (Layer 3 Lite) Gigabit managed switches perfect for data center access, SMB core/aggregation, and mission critical PoE applications. The high redundancy hardware architecture includes dual, internal power supplies and hot-swappable fan and power modules. The PoE models also comply with the IEEE 802.3at PoE Plus standard and provide industry-leading PoE power budget of up to 1000 watts. -
Resiliency and availability for non-stop business continuity
The ZyXEL XGS3700 series features a no single point of failure (NSPOF) hardware and software design to provide the resiliency needed for non-stop business continuity. Its high redundancy hardware architecture includes dual, internal power supplies - which not only ensures 100% uptime in the event of a power supply failure, but also saves rack space compared to external power supplies. Additionally, both the fan module and the power supply modules are hot-swappable to enable zero downtime troubleshooting. -
High power capacity and high availability for mission critical PoE applications
The complete PoE portfolio provides up to 30 watts per port with IEEE 802.3at PoE Plus compliance, and is backward compatible with the IEEE 802.3af standard. This model provides an industry-leading PoE power budget of 1000 watts with dual power supply units or 460 watts with a single power supply unit. Combined with the high resiliency hardware and software features, the XGS3700 series PoE switches are ideal for mission critical IP surveillance, WLAN and high quality VoIP applications. -
Deployment flexibility and investment protection
- Zyxel XGS3700-48 - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - L2+ - Managed - stackable
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 + 4 x 10 Gigabit SFP+
- Performance
- Switching capacity: 176 Gbps , Forwarding performance: 131 Mpps
- Capacity
- Routing table entries: 512 , Routing domains: 128
- MAC Address Table Size
- 16K entries
- Routing Protocol
- IGMPv2, IGMP, VRRP, static IP routing, IGMPv3, ECMP, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2, CLI
- Flow control, ARP support, trunking, IGMP snooping, Syslog support, traffic shaping, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, IP address filtering, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Weighted Fair Queuing (WFQ), ZyXEL iStacking Technology, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Route Redundancy Protocol (VRRP) support, VLAN Stacking, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, RADIUS support, DHCP server, MLD snooping, bandwidth control, Equal-Cost Multipath (ECMP), LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), NTP server, IP-MAC binding, DHCP client, Management Information Base (MIB), Multicast VLAN Registration (MVR), dual firmware images, Strict Priority Queuing (SPQ), 2MB packet buffer, loop prevention, port isolation, hot swappable fan, Class of Service (CoS), tagged VLAN, Generic VLAN Registration Protocol (GVRP), IGMP proxy
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.3aq, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 44 cm x 43.7 cm x 4 cm
- 7.57 kg
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 16K entries
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- 48 x 1000Base-T RJ-45 , 4 x SFP+ , 1 x console - 9 pin D-Sub (DB-9) , 1 x RJ-45 management
- Power Device
- Internal power supply
- Installed Qty
- 1 (installed) / 2 (max)
- Power Redundancy
- Optional
- Voltage Required
- 66.9 Watt
- MTBF
- 250,000 hours
- BSMI, RoHS, FCC Part 15 B Class A, LVD, EMC Class A
- 44 cm
- 43.7 cm
- 4 cm
- 7.57 kg
- 0 °C
- 50 °C
- 10 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 10 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.20 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £11.76 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £7.24 |
