ZyXEL WRE2206 Wireless N300 Range Extender is to extend your home wireless (Wi-Fi) network to those areas with unreliable signal. The WRE2206 is optimized for the best Wi-Fi experience and delivers up to 30% better coverage than ordinary Wi-Fi extenders with its power amplified antennas. The one-touch WPS button makes it simple to extend your existing Wi-Fi network, while the LED indicator helps you find the best location for the extender.
Power boosted internals for better coverage
The ZyXEL WRE2206 uses additional power to boost its wireless signals providing improved wireless coverage. -
Simple to setup
ZyXEL's WRE2206 range extender makes improving your Wi-Fi network easy. Just plug the range extender in and push its WPS button, then push the WPS button on your router or access point - and just like that, you've successfully extended your Wi-Fi network. -
LED indicator for the best location to extend your wireless network
Where you install the extender makes a real difference. Plus, with the same LEDs, ZyXEL WRE2206 shows you how many devices are connected to the extender and gives you an indication how this will affect performance. -
Compact design for easy, unobtrusive placement
Easily plug in the wireless extender without messy wiring like typical access points. Keep your home looking clean with its unobtrusive design.
- Zyxel WRE2206 - Wi-Fi range extender - Wi-Fi
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Power
- AC 120/230 V (50/60 Hz)
- 5.5 cm x 8.3 cm x 7.8 cm
- 68 g
- 5.5 cm
- 8.3 cm
- 7.8 cm
- 68 g
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Status Indicators
- Power, signal strength, WPS
- Auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, firmware upgradable, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS)
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- Gain Level
- 2 dBi
- 1 x 100Base-TX - RJ-45
- Cables Included
- 1 x network cable
- FCC, LVD
- Power Device
- Internal power supply
- Voltage Required
- 3 Watt
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
