Suffering from poor wireless connectivity at home with your old router? Eliminate the frustration by providing a powerful network with wider coverage and stronger signal strength.
Optimized Mesh powered by WiFi 6
Multy M1 equipped with the latest WiFi 6 technology which has been designed to offer faster and ef?cient connections especially in device dense environments.
Massive Capacity
4 times data capacity to servemore connected networking devices
Maximum Speed
Insanely fast WiFi throughput for improved gaming, streaming, and smart home experience
More Efficiency
OFDMA, DL/UL MU-MIMO improving traf?c efficiency. Suitable for high bandwidth applications and large packet transmission
Seamless roaming, one WiFi name
Multy creates a single wireless network name and password, allowing you to roam, work and play freely throughout your home without the need to reconnect to another network.
Flexible wired and wireless connection
Operate your local network at full capacity with Gigabit solution! Each Multy M1 device equipped with four gigabit Ethernet LAN ports, which can be used to connect to more devices like media servers, NAS storage devices, switches, and other Smart Home devices.
- Zyxel Multy M1 WSM20 - Wi-Fi system - Wi-Fi 6 - desktop, wall-mountable
- Wi-Fi system - mesh
- Enclosure Type
- Desktop, wall-mountable
- Wi-Fi System Components
- 3 routers
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
- Frequency Band
- 2.4 GHz / 5 GHz
- Performance
- Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 1201 Mbps
- Capacity
- SSIDs total: 3
- TCP/IP, PPTP, L2TP, IPSec, PPPoE, DHCP, DDNS, IPv4, IPv6, OpenVPN
- Routing Protocol
- IGMPv2, IGMP, static IP routing, IGMPv3
- Intelligent Assistant
- Alexa
- NAT support, auto-uplink (auto MDI/MDI-X), Stateful Packet Inspection (SPI), DoS attack prevention, MAC address filtering, parental control, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Wi-Fi Protected Setup (WPS), IPSec passthrough, DHCP server, Multiple SSID support, reset button, DHCP client, dual-stream (2x2), VPN Server, PPTP passthrough, Single Sign-On (SSO) support, L2TP passthrough, MU-MIMO technology, beamforming technology, Multicast to Unicast Conversion, band steering, VPN client, push notification, router mode, LED on/off button, guest access, bridge mode, Orthogonal Frequency Division Multiple Access (OFDMA), WPS button, auto firmware update, guest Wi-Fi, traffic separation from host network, AP steering
- 13.3 cm x 19.2 cm x 6.6 cm
- 254 g
- Wi-Fi system - mesh - 3-port switch (integrated)
- 3 routers
- Enclosure Type
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Performance
- Capacity
- SSIDs total: 3
- Routing Protocol
- Encryption Algorithm
- WPA3-PSK
- Authentication Method
- Radio Service Set ID (SSID)
- Wi-Fi Rating
- AX1800
- Mesh Networking
- BSMI, FCC, LVD, NCC
- Processor
- 1 x 880 MHz
- RAM
- 256 MB
- Flash Memory
- 128 MB
- Status Indicators
- Status
Line Properties
- Line Coding Format
- 1024 QAM
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Alexa
- LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- Internal
- Antenna Qty
- 2
- Power Device
- External power adapter
- 15 Watt
- Included Accessories
- 3 x wall mounting kits
- Cables Included
- Network cable
- 13.3 cm
- 19.2 cm
- 6.6 cm
- 254 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HB1B 047683 Condition: Customer return - item has been opened but is in excellent condition |
£52.56 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
