Zyxel NWA55AXE, Outdoor Standalone / NebulaFlex Wireless AP
Quicklinx: HHZ1WS00 Mfr#: NWA55AXE-GB0102F
£85.02 ex VAT
£102.02 inc VAT
Thinking of upgrading to the 11ax (Wi-Fi 6) technology for your outdoor wireless network? Zyxel NWA55AXE is your answer! Designed for harsh outdoor environments, the IP55-rated, weatherproof NWA55AXE is the best Wi-Fi 6 outdoor access point to extend your wireless network outside. The embedded Zyxel Smart Mesh Technology not only forms dynamic wireless links between APs for extended range, but can also bridge the wireless connectivity from one building to another. It is no doubt that NWA55AXE is an ideal choice for a simple expansion of your outdoor wireless network or forming an interconnected wireless network through outdoor inter-building links.
The downward pointing antenna position of NWA55AXE provides better protection against rain and moisture, whereas the traditional, upward pointing antenna design is prone to water leaks, having a potential of damaging the access point's internals. The external, detachable antenna design allows users to attach other antennas to better suit different demands. Perfect for small business owners or SOHO users, the NWA55AXE supports both local GUI management and Nebula Cloud networking management. The simple setup allows you to quickly configure the AP with only a few clicks, making it super easy to set up guest and employee network on your own and start enjoying the ultra-fast Wi-Fi 6 speeds in no time.
  • Effortless deployments and lower initial investment
    Deployment of outdoor access points is a complex task that involves cabling, installation and maintenance. The NWA55AXE simplifies the process with its Smart Mesh Technology and external, detachable antennas that save your effort to install and adjust signal patterns. This makes NWA55AXE an ideal solution to extend reliable wireless connectivity to outdoor environments at an affordable price.
  • Bringing next generation Wi-Fi within reach
    Wi-Fi 6 made tremendous improvement by introducing new technologies, such as orthogonal frequency-division multiple access (OFDMA), and spatial re-use, which is also referred to as Basic Service Set (BSS) coloring. It aims to simultaneously satisfy all requirements from rapidly growing mobile users. Zyxel's NWA55AXE is a true Wi-Fi 6 access point which support essential 11ax functions that delivers faster performance and massive increased capacity, making the user experience even better. Apart from running at 25% faster speed, NWA55AXE can also maximize Wi-Fi efficiency by allowing simultaneous data transmission for multiple clients; thus, the airtime contention is no longer an issue here.
  • NebulaFlex - simply manage it your way
    The NebulaFlex provides extended flexibility, allowing users to easily switch between standalone and intuitive cloud-managed NCC (Nebula Control Center) mode any time according to your needs without additional cost while protecting wireless technology investments. The Nebula cloud management platform provides centralized control and visibility over all Nebula networking devices. You simply need to register the device on NCC, and it will automatically join, auto provision and begin to give real-time information. The intuitive platform allows you to group your access points together, control centrally, gain access to diagnostics tools and additional features like captive portal all under a single platform.
Zyxel NWA55AXE - radio access point - Wi-Fi 6 - cloud-managed
Radio access point
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum data rate (2.4 GHz): 575 Mbps , Maximum data rate (5 GHz): 1200 Mbps
PoE injector
Power Over Ethernet (PoE) Supported
PoE
30.8 cm x 13.64 cm x 4.96 cm
580 g
Radio access point
30.8 cm
13.64 cm
4.96 cm
580 g
United Kingdom
External
Wireless
Data Transfer Rate
1200 Mbps
Remote Management Protocol
HTTP
Cloud-Managed
Frequency Band
2.4 GHz, 5 GHz
Performance
Wi-Fi Rating
AX1800
VLAN support, MAC address filtering, IPv6 support, firmware upgradable, Unscheduled Automatic Power Save Delivery (U-APSD)
Encryption Algorithm
WPA3-Personal, WPA2-Personal, WPA-Personal
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac, IEEE 802.11ax
Aerial
Antenna
External
Antenna Qty
2
1 x 1000Base-T - RJ-45
PoE injector
MTBF
1,091,186 hour(s)
EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, FCC Part 15 B, FCC Part 15 C, RoHS, IEC 60950-1, EN 60950-1, FCC Part 15 E, BSMI CNS 13438, EN 60601-1-2, BSMI CNS 14336-1, EN 301 489-1, LP0002, ETSI EN 300 328, EN 301 893, EN 301 489-17
PoE
Shipping Width
22.1 cm
Shipping Depth
18.8 cm
Shipping Height
5.9 cm
Shipping Weight
887 g
-20 °C
60 °C
10 - 90% (non-condensing)
Brand: Zyxel
