The NWA90AX is an excellent choice for small and medium-sized businesses that want to benefit from an ax11 (WiFi 6) access point at the best possible price. It supports both 2.4 and 5 GHz frequencies, so you can make the most of everything WiFi 6 has to offer: higher speeds, even in dense environments, wider coverage and greater IoT deployment capability.
No network expertise required
The NWA90AX can be installed and configured by anyone, whether in small hotels, cafés, telecommuting configurations, stores or businesses. It supports local management via web interface or Nebula cloud management. With just a few clicks, you can quickly set up your access point and easily create a network for your staff and another for guests, so you can immediately enjoy your new ultra-fast WiFi 6 network. -
Secure WiFi authentication for enhanced business protection
With support for captive portal and IEEE802.1x authentication, the NWA90AX offers small and medium-sized businesses not only enterprise-grade security to protect their networks, but also the ability to customize the WiFi network user login for marketing and corporate recognition. -
You're in charge
The NebulaFlex-enabled NWA90AX gives you the freedom to choose how you manage your network. With an intuitive web interface on your PC or Nebula's super-easy cloud management, you'll never forget a username, password or IP address again.
- Zyxel NWA90AX - radio access point - Wi-Fi 6 - cloud-managed
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Maximum data rate (2.4 GHz): 575 Mbps , Maximum data rate (5 GHz): 1200 Mbps
- Included Accessories
- Mounting screws, mounting plate
- Power Over Ethernet (PoE) Supported
- PoE+
- Power
- AC 100-240 V (50/60 Hz)
- 14 cm x 14 cm x 3.75 cm
- 290 g
- 14 cm
- 14 cm
- 3.75 cm
- 290 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1775 Mbps
- IPv6
- Remote Management Protocol
- HTTP, CLI
- Cloud-Managed
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, firmware upgradable, Wi-Fi Multimedia (WMM) support, rogue access point detection, dual-stream (2x2), MU-MIMO technology, Unscheduled Automatic Power Save Delivery (U-APSD), band steering, Fast Roaming, Dynamic Channel Selection (DCS), Layer 2 isolation, Smart Mesh technology
- Encryption Algorithm
- WPA2-PSK, WPA2-Enterprise, WPA3-Personal, WPA2-Personal, WPA-Personal
- Authentication Method
- RADIUS, Extensible Authentication Protocol (EAP)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac, IEEE 802.11ax
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- 1 x 1000Base-T (PoE+) - RJ-45
- MTBF
- 1,010,980 hours
- BSMI, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, FCC Part 15 B, FCC Part 15 C, RoHS, IEC 60950-1, EN 60950-1, FCC Part 15 E, BSMI CNS 13438, EN 60601-1-2, EN 301 489-1, LP0002, CNS 14336-1, ETSI EN 300 328, EN 301 893, EN 301 489-17
- PoE+
- Power Device
- External power adapter
- Voltage Required
- Shipping Width
- 24 cm
- Shipping Depth
- 15.5 cm
- Shipping Height
- 6 cm
- Shipping Weight
- 600 g
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
