Powered by the IEEE 1901 technology and four Gigabit Ethernet ports, the ZyXEL PLA4225 500 Mbps powerline 4-port gigabit switch provides an all-in-one solution for users looking to enjoy multiple HD streams, multiplayer gaming and web surfing simultaneously. When used alongside a powerline Ethernet adapter, the PLA4225 makes it simple to connect up to four media devices such as HDTVs, Blu-ray players, DVRs, and game consoles to your home network through any electrical outlet in your house.
Blazing speed lives up your multimedia streams
Powered by the IEEE 1901 technology and four Gigabit Ethernet ports, the ZyXEL PLA4225 500 Mbps powerline 4-port gigabit switch provides an all-in-one solution for users looking to enjoy multiple HD streams, multiplayer gaming and web surfing simultaneously. When used alongside a powerline Ethernet adapter, the PLA4225 makes it simple to connect up to four media devices such as HDTVs, Blu-ray players, DVRs, and game consoles to your home network through any electrical outlet in your house. -
QoS enhances media streaming quality
Advanced Quality of Service (QoS) features improve the quality of streaming multimedia applications such as triple-play services, HD video streaming, high-speed Internet access and VoIP. -
Green technology saves energy
The PLA4225 automatically enters power-saving mode when an inactive Ethernet connection is detected, reducing energy consumption by 80% when compared to powerline adapters without this function. -
Easy security setup
Data transmission is protected by 128-bit Advanced Encryption Security (AES) to ensure a secure connection to the Internet. There's no complicated setup or software required - the PLA4225 makes network security as simple as pushing a button.
- Zyxel PLA4225 - powerline adapter - wall-pluggable
- Powerline adapter - 4-port switch (integrated)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), IEEE 1901
- Data Transfer Rate
- 500 Mbps
- CSMA/CA
- 128-bit encryption, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Quality of Service (QoS)
- HomePlug AV, IEEE 1901
- Power
- AC 120/230 V (50/60 Hz)
- 7.6 cm x 7.2 cm x 10.8 cm
- 160 g
- System Requirements
- Microsoft Windows Vista / XP / 7
- Localisation
- United Kingdom
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 500 Mbps
- CSMA/CA
- Encryption Algorithm
- 128-bit AES
- HomePlug AV, IEEE 1901, FCC, RoHS
- Status Indicators
- Power, link/activity
- 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV
- Power Device
- Internal power supply
- Voltage Required
- 5 Watt
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- OS Required
- 7.6 cm
- 7.2 cm
- 10.8 cm
- 160 g
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
