Powered by the IEEE 1901 technology and a Gigabit Ethernet port, ZyXEL's 500 Mbps Powerline Gigabit Ethernet adapter can provide a stable high-performance network for you to enjoy multiple HD streams, multiplayer gaming and web surfing simultaneously.
With a pair of Plug-and-Play PLA4205 installed, you can easily extend your home network through any electrical outlet for Internet access by HDTVs, Blu-ray players, DVRs, PCs and game consoles.
Blazingly fast speed
Powered by the IEEE 1901 technology and a Gigabit Ethernet port, ZyXEL's 500 Mbps Powerline Gigabit Ethernet adapter can provide a stable high-performance network for you to enjoy multiple HD streams, multiplayer gaming and web surfing simultaneously. -
Enjoy stable HD videos and gaming
With a pair of Plug-and-Play PLA4205 installed, you can easily extend your home network through any electrical outlet for Internet access by HDTVs, Blu-ray players, DVRs, PCs and game consoles. -
QoS enhances media streaming quality
The advanced Quality of Service (QoS) features improve the quality of multimedia streaming applications such as Triple Play services, HD video streaming, high-speed Internet access and VoIP.
- Zyxel PLA4205 - powerline adapter - wall-pluggable
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV)
- Data Transfer Rate
- 500 Mbps
- CSMA/CA
- 128-bit encryption, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Quality of Service (QoS)
- HomePlug AV, IEEE 1901
- Power
- AC 120/230 V (50/60 Hz)
- 7.1 cm x 6.5 cm x 9.5 cm
- 134 g
- Localisation
- United Kingdom
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 500 Mbps
- CSMA/CA
- Encryption Algorithm
- 128-bit AES
- HomePlug AV, IEEE 1901, UL, cUL, EMC, FCC, RoHS
- Status Indicators
- Power, link/activity
- 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV
- Power Device
- Internal power supply
- Voltage Required
- 5 Watt
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- 7.1 cm
- 6.5 cm
- 9.5 cm
- 134 g
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
