Zyxel PLA4201 500Mbps Mini Powerline Ethernet Adaptor Twin Pack
Quicklinx: 83VCWS00 Mfr#: PLA4201-GB0201F
New V2 Version Available Here
Kit Contains 2 units
Extend Home Networks Effortlessly with the Most Compact Powerline Adapter
The ZyXEL PLA4201 500 Mbps Mini Powerline Ethernet Adapters improves up to 60% performance for stable HD media streaming compared with 200 Mbps powerline technology. Just plug a pair of PLA4201 into electric outlets and connect to network devices, then you can enjoy HD media streams, multiplayer gaming and other network applications in every room simultaneously right away.
Compact design for easy setup and instant plug-and-play
The new mini-size ZyXEL PLA4201 gives you the flexibility to turn power lines into a home network. The compact design allows hassle-free installation without blocking other power outlets. With a pair of plug-and-play PLA4201, you can easily extend your home network through any electrical outlet for Internet access from HDTVs, Blu-ray™ players, DVRs, PCs and game consoles.
Enjoy stable HD videos and gaming
Powered by the IEEE 1901 technology, the ZyXEL PLA4201 can provide a stable high-performance network for users to enjoy multiple HD streaming, multiplayer gaming, and Web surfing simultaneously.
QoS enhances media streaming quality
The advanced Quality of Service (QoS) features improve the quality of multimedia streaming applications such as Triple Play services by prioritizing HD video streaming, high-speed Internet access and VoIP traffic.
Power-saving mode
When there is no Ethernet link, the PLA4201 enters a power-saving mode with just 0.5 watt consumption to reduce the energy waste by around 88%.
3 Year Warranty
  • Compact design for easy setup and instant Plug-and-Play
    The mini-size ZyXEL PLA4201 gives you the flexibility to turn power lines into a home network. The compact design allows hassle-free installation without blocking other power outlets. With a pair of Plug-and-Play PLA4201, you can easily extend your home network through any electrical outlet for Internet access from HDTVs, Blu-ray players, DVRs, PCs and game consoles.
  • Enjoy stable HD videos and gaming
  • QoS enhances media streaming quality
    The advanced Quality of Service (QoS) features improve the quality of multimedia streaming applications such as Triple Play services by prioritizing HD video streaming, high-speed Internet access and VoIP traffics.
  • Green product saves energy consumption
    When there is no Ethernet link, the PLA4201 enters a power-saving mode with just 0.5 W consumption to reduce the energy waste by around 88%.
  • Easy security setup
    Data transmission is protected by 128-bit Advanced Encryption Security (AES) to provide a secure connection to the Internet.
Zyxel PLA4201 - Starter Kit - powerline adapter kit - wall-pluggable
Powerline adapter kit
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, HomePlug AV (HPAV), IEEE 1901
Data Transfer Rate
500 Mbps
Network / Transport Protocol
CSMA/CA
128-bit encryption, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Quality of Service (QoS), reset button
HomePlug AV, IEEE 1901
AC 230V (50/60 Hz)
5 cm x 6 cm x 9 cm
72 g
Microsoft Windows Vista / XP / 7
United Kingdom
Packaged Quantity
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
CSMA/CA
Encryption Algorithm
128-bit AES
HomePlug AV, IEEE 1901, FCC, RoHS, LVD
Status Indicators
Power, link/activity
1 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV - power BS 1363
Internal power supply
AC 230V (50/60 Hz)
4 Watt
ZyXEL 500 Mbps Mini Powerline Ethernet Adapter (PLA4201)
1 x network cable
United Kingdom
5 cm
6 cm
9 cm
72 g
10 - 90% (non-condensing)
