Brand
Zyxel NWA5123-AC (8 Pack) no PSU Standalone + Controller AP
Quicklinx: BW51WS00 Mfr#: NWA5123-AC-EU0201F
  • IEEE 802.11n
The ZyXEL NWA5120 series 802.11n/ac unified access point is WLAN solution perfect for growing business, hospitality and education environments. With a 2-in-1 standalone/managed AP design, users can initially use it as a standalone AP, and convert it to a controller-managed AP when Wi-Fi demand grows. The series is designed with advanced technology to provide trouble-free wireless quality to lower IT overhead. The embedded antennas and signal output are fine-tuned to provide easy RF planning and maximum signal coverage. It also supports such features as dynamic channel selection, load balancing and preauthentication for superb Wi-Fi experience.
  • Ceiling-mount design blends into environments
    Different from traditional business routers, the slick smoke detector ceiling-mount design of ZyXEL NWA5120 series provides better coverage and performance. The NWA5120 series is a PoE AP with a multifunction design that solves all problems by offering internal as well as external antennas to enhance wireless performance and to eliminate coverage dead spots. Moreover, the signal outputs have been fine-tuned to provide easy RF planning and excellent signal coverage especially for hospitality and education environments. The ZyXEL NWA5120 series has been made of non-toxic materials without hazardous emission - the safe design makes it more suitable for public indoor wireless deployments.
  • Effortless conversion from standalone to centrally-managed
    The ZyXEL NWA5120 series unified APs can be configured as a fully functional standalone AP and also capable to work with wireless LAN controller to form a robust controller-based WLAN solution with centralized management when Wi-Fi demand grows, as well as auto AP provisioning over both LAN and WAN connections. After being installed and powered on, the APs automatically look for the wireless LAN controller and establish connections. Utilizing the CAPWAP protocol, connections can be established between the controller and APs without needing to change the existing LAN infrastructure.
  • Ultra-fast Gigabit Wi-Fi experience
    Featuring the advanced 802.11ac standard, the NWA5123-AC not only provides high data rates, but also optimizes signal with its advanced antenna design to amazing user experience through a higher number of parallel video data streams for minimized latency on the network. Additionally, the concurrent dual-band support is perfect for high-density applications such as hospitality, education and business.
  • Streamlined deployments for optimized WLAN experience
    The NWA5120 series features APFlexTM to simplify managed/standalone AP mode configuration to integrate with network environments automatically and to eliminate the need for pre-install preparations. To deliver optimized wireless experience for users, the NWA5120 series features Dynamic Channel Selection (DCS), Load Balancing and Smart Client Steering. Dynamic Channel Selection (DCS) avoids interference from co-channel and channel overlapping at initialization, while Load Balancing enables administrators to set limits on the number of clients associated with each AP. Furthermore, Smart Client steering features Band Select, Signal Threshold and Band Balancing for stable, reliable wireless connections. Band Select and Signal Threshold monitor the capabilities of each wireless client and steer them to the less-congested band and the AP with better signal. These advanced functions ensure the NWA5120 series to provide a smooth, consistent and uninterrupted wireless access experience.
Zyxel NWA5123-AC - radio access point
Radio access point
Packaged Quantity
8 (specifications are for single item)
External
Europe
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 16
Wall/ceiling mounting plate
Power Over Ethernet (PoE) Supported
PoE
13 cm x 13 cm x 5.47 cm
300 g
Packaged Quantity
Radio access point
13 cm
13 cm
5.47 cm
300 g
Europe
External
Wireless
Data Transfer Rate
1200 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
Spread Spectrum Method
OFDM, DSSS
Remote Management Protocol
CLI
Frequency Band
2.4 GHz, 5 GHz
VLAN support, manageable, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), CAPWAP support, plenum-rated, DHCP client, ceiling mountable, Maximum Likelihood Demodulation (MLD), ZyXEL One Network (ZON), ZyXEL Wireless Optimizer (ZWO), ZyXEL APFlexT
Encryption Algorithm
TLS, PEAP, TTLS, WPA2, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, WEP
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
4
1 x 1000Base-T (PoE) - RJ-45
MTBF
1,727,244 hours
BSMI, EN 61000-3-2, EN 61000-3-3, FCC Part 15.247, FCC Part 15 E, EN55022:2010, IEC 60950-1:2005, EN 60601-1-2:2007, EN 301 489-17 V2.1.1 (2009-05), EN 55024:2010, CNS 14336:1999, EN 300 328 V1.7.1 (2006-11), ETSI EN 301 893 V1.5.1, LP0002, ETSI EN 301 489-1 V1.8.1 (2008-11), BSMI CNS 13438(99), EN 60950-1:2006+A11:2009+A1:2010+A12:2011
PoE
50 °C
10 - 90% (non-condensing)
