Zyxel MS7206S 6 Slot Chassis Switch Fibre Bundle
Quicklinx: 8PF5WS00 Mfr#: 96-996-000046
If ZyXEL's MS-7206S was a person, it would have quite the hat collection. The MS-7206S, due to its power and modularity, is a switch that can be used in a lot of different roles. It can be a SMB core switch, a distribution switch for Enterprise and Campus deployments, an intelligent switch for Enterprise, or an aggregation switch for data centers and telcos.
This modular switch offers intelligent L2/L3/L4 local switching and advanced management features. It's ideal for large business and campus networks.
  • Unbeatable performance and scalability
    Implement campus and building backbone networks support thousands of users.
  • Fault-free with automatic recovery
    OSPF ensures rapid determination of best routes (convergence), avoid routing loops. Rapid spanning tree provides Layer 2 resilience and prevent loops.
  • Secured connectivity
    Sophisticated Layer 2 to Layer 4 ACL (Access Control List) makes security policy to be applied at LAN easily.
Zyxel MS-7206S PoE Bundle - switch - 48 ports - Managed
Switch - 48 ports - L4 - Managed
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE)
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP, VRRP, OSPFv2, static IP routing, IGMPv3
Remote Management Protocol
RMON 1, RMON 2, SNMP, RMON 3, RMON 9, SNMP 2c, HTTP
Flow control, modular design, hot swap module replacement, Layer 4 switching, Layer 3 switching, Layer 2 switching, power over Ethernet (PoE), auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, manageable, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, firmware upgradable, Weighted Fair Queuing (WFQ), Access Control List (ACL) support, Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
43.5 cm x 31.6 cm x 44.7 cm
15.5 kg
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), Secure Shell v.2 (SSH2)
Status Indicators
Power, system, status
48 x 10Base-T/100Base-TX/1000Base-T - RJ-45 PoE , 1 x 10Base-T/100Base-TX - RJ-45 management , 1 x RS-232 - 9 pin D-Sub (DB-9) management , Accessory: 1 x RS-232 - 9 pin D-Sub (DB-9)
Expansion Slots
6 (total) / 3 (free) x Expansion Slot
Installed Modules Qty (Max)
3 (installed) / 6 (max)
Internal power supply
Installed Qty
2
Max Supported Qty
2
600 Watt
43.5 cm
31.6 cm
44.7 cm
15.5 kg
