Zyxel 802.11bgn Wireless Access Point
Quicklinx: 8XG4WS00 Mfr#: NWA5121-N-EU0101F
The ZyXEL NWA5120 series 802.11 a/b/g/n unified access point is a highly future-proof WLAN solution perfect for growing business, hospitality and education environments. With a 2-in-1 standalone/managed AP design, users can initially use it as a standalone AP, and convert it to a controller-managed AP when Wi-Fi demand grows. The series is designed with industry-leading technology to provide trouble-free wireless quality to lower IT overhead. The embedded antennas and signal output are fine-tuned to provide easy RF planning and maximum signal coverage. It also supports such features as dynamic channel selection, load balancing and pre-authentication for superb Wi-Fi experience.
  • Ceiling-mount design blends into environments
    Different from traditional business routers, the slick smoke detector ceiling-mount design of ZyXE NWA5120 series provides better coverage and performance. The NWA5120 series is a PoE AP with a multifunction design that solves all problems by offering internal as well as external antennas to enhance wireless performance and to eliminate coverage dead spots. Moreover, the signal outputs have been ine-tuned to provide easy RF planning and excellent signal coverage especially for hospitality and education environments. The ZyXEL NWA5120 series has been designed with plenum rating and made of non-toxic materials without hazardous emission the safe design makes it more suitable for public indoor wireless deployments.
  • Effortless conversion from standalone to centrally-managed
    The ZyXEL NWA5120 series Unified APs can be configured as a fully functional standalone AP and also capable to work with Wireless LAN Controller to form a robust controller-based WLAN solution with centralized management when Wi-Fi demand grows, as well as auto AP provisioning over both LAN and WAN connections. After being installed and powered on, the APs automatically look for the wireless LAN controller and establish connections. Utilizing the CAPWAP protocol, connections can be established between the controller and APs without needing to change the existing LAN infrastructure.
  • Continuous wireless services for better reliability and network quality
    The ZyXEL NWA5120 series 802.11n PoE AP features coverage-enhancing 11n technologies such as TX Beamforming, LDPC and MLD to eliminate issues of dead spots and incipient coverage. With MLD, the NWA5120 series boosts the Signal-to-Noise Ratio (SNR) to 3 dB for more stable wireless services and better performance. Meanwhile, TX beam forming also eliminates dead spots by expanding the coverage with continuous, dynamic changing of signal phases. With non-stop wireless services, the NWA5120 series provides reliable network connectivity for better business productivity.
Zyxel NWA5121-N - radio access point - Wi-Fi
Radio access point
In-ceiling
Europe
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
DC 12 V
13 cm x 13 cm x 5.45 cm
230 g
Radio access point
13 cm
13 cm
5.45 cm
230 g
Europe
In-ceiling
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK
Spread Spectrum Method
DSSS
Remote Management Protocol
CLI
Frequency Band
2.4 GHz
VLAN support, manageable, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), CAPWAP support, Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, plenum-rated, DHCP client, Energy Efficient Ethernet, Maximum Likelihood Demodulation (MLD)
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, WEP
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna Qty
2
Gain Level
3 dBi
1 x 100Base-TX (PoE) - RJ-45
MTBF
627,152 hours
BSMI, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, FCC Part 15.247, IEC 60950-1, EN 60950-1, FCC Part 15.107, BSMI CNS 13438, BSMI CNS 14336, IEC 60601-1-2:2007, EN 300 328 V1.7.1, EN 301 489-1, EN 301 489-17
PoE
Internal power supply
DC 12 V
4 Watt
50 °C
10 - 90% (non-condensing)
