Centralized administration simplifies planning significantly. The NWA5000-N series is designed to enable easy deployment and instant provisioning. The NWA5000-N series supports the 802.3af or 802.3at Power over Ethernet (PoE) standard to utilize the Ethernet cable for minimized cabling construction.
To IT administrators, one of the major concerns is to deploy a WLAN infrastructure with flexible guess access while providing internal users a separated secure network at the same time. The NWA5000-N series features end-to-end guest network solutions to provide a guest account generator and web authentication functions. The ZyXELNWA5000-N series can eliminate concerns for IT administrators while providing the best Wi-Fi coverage at the same time. It is an ideal and secure choice for business Wi-Fi deployments.
Full performance without concerns
The NWA5000-N series can offload the network burden while allowing users to enjoy the 11n wireless performance. -
Zero-configuration construction for minimized provisioning efforts
Centralized administration simplifies planning significantly. The NWA5000-N series is designed to enable easy deployment and instant provisioning. The NWA5000-N series supports the 802.3af or 802.3at Power over Ethernet (PoE) standard to utilize the Ethernet cable for minimized cabling construction. -
Easy, comprehensive guest network management
- Zyxel NWA-5550-N - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External - outdoor
- Localisation
- Europe
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Throughput: 140 Mbps
- Power Over Ethernet (PoE) Supported
- PoE
- 25.7 cm x 25.7 cm x 5.1 cm
- 1.36 kg
- Ruggedized Design
- Outdoor
- 25.7 cm
- 25.7 cm
- 5.1 cm
- 1.36 kg
- Localisation
- Europe
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
- Remote Management Protocol
- SSH, CLI
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Status Indicators
- Power, system, WLAN, LAN
- Power over Ethernet (PoE), VLAN support, manageable, Wireless Distribution System (WDS) support, full duplex mode, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Auto Traffic Classifier (ATC), Multiple SSID support, wireless bridge mode, 2T2R MIMO technology, DHCP client
- Encryption Algorithm
- WPA2, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
- Authentication Method
- Secure Shell (SSH)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az
- 1 x 1000Base-T - RJ-45 , 1 x management , 4 x aerial - N connector
- FCC Part 15 B, FCC Part 15 C, UL 2043, FCC, RoHS, EN 60950-1, FCC Part 15 E, EN 60601-1-2, DGT, EN 300 328, EN 301 489-1, EN 301 893, EN 301 489-17
- PoE
- -40 °C
- 40 °C
- 10 - 90% (non-condensing)
