Within business today companies continually face the challenge of providing wireless access to guests and mobile employees without compromising security. To address this situation ZyXEL has developed the NWA5560N WLAN Access Point. The solution is designed to deliver high performance 11n wireless to provide seamless mobility in medium to large campus and secure distributed enterprise environments.
Central configuration
This w secure WLAN solution is based on the ZyXEL NWA5560N managed access points that provides comprehensive wireless coverage. -
Better wireless experience
Central administration simplifies planning immensely. The managed access points are first installed at the most suitable locations for WLAN reception. Areas with insufficient coverage or too low data speeds can be made accessible with additional managed access points. The best results can be obtained however when a site survey is carried out enabling a simplified installation and better wireless experience. -
Captive portal
A captive portal intercepts all network traffic regardless of address or port until users authenticate their identity through a designated login web page. As an added security measure, the NXC contains captive portal functionality; this means that all web page requests can be initially redirected to a special web page that requires guests to authenticate their sessions.
- Zyxel NWA-5560-N - radio access point - Wi-Fi
- Radio access point
- Packaged Quantity
- 6 (specifications are for single item)
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Throughput: 140 Mbps
- Power Over Ethernet (PoE) Supported
- PoE
- 21.8 cm x 17.4 cm x 5.4 cm
- 1.36 kg
- Packaged Quantity
- 21.8 cm
- 17.4 cm
- 5.4 cm
- 1.36 kg
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
- Remote Management Protocol
- SSH, CLI
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Auto-sensing per device, DHCP support, power over Ethernet (PoE), VLAN support, Wireless Distribution System (WDS) support, full duplex mode, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Auto Traffic Classifier (ATC), 2T2R MIMO technology
- Encryption Algorithm
- WPA2, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
- Authentication Method
- Secure Shell (SSH)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az
Aerial
- Antenna
- External detachable
- Antenna Qty
- 4
- Directivity
- Omni-directional
- 1 x 1000Base-T - RJ-45
- FCC Part 15 B, FCC Part 15.247, FCC Part 15 C, RoHS, EN 60950-1, FCC Part 15 E, EN 60601-1-2, DGT, EN 300 328, EN 301 489-1, EN 301 893, EN 301 489-17
- PoE
- Power Device
- External power adapter
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
