The front mesh bay cover provides cool air into the system while dust filters prevent dust from entering. It has interactive cooling system: Hot air generated from HDD is expelled through both sides. Cooling performance is maximized for HDD cooling, and the overall PC exhaust is increased. For user convenience, top air vents expel exhaustive air from the top cooling fan. In addition, translucent acryl vents are effective for tuning.
Front Mesh Cover for High Cooling Performance
Supports up to 7 System Fans
Up to 7 system fans are installed to expel hot air effectively from the case.
Zalman's Powerful HDD Cooling Solution
Interactive Cooling System : Hot air generated from HDD is expelled through both sides. Cooling Performance is maximized for HDD cooling, and the overall PC exhaust is increased.
Top Air Vent Exhaust/Tuning
For for user convenience, Top air vents expel exhaustive air from the top cooling fan. In addition, translucent acryl vents are effective for tuning.
Side-Panel Acryl Tuning
Dynamic Side Acryl Tuning is provided for users to view the interior of gaming system.
Supports Dual USB 3.0 Ports
I/O module provides dual USB 3.0 ports for user convenience and expandability.
Dust Filters for Front and Bottom of System and PSU
Dust filters in the front and bottom mesh covers prevent dust from entering the system and keep the internal components dust-free.
Additional Card Holder Provided
When installing VGA Card and PCI Slot, the bracket can be used permanently.
Supports Bottom PSU Installation and Aperture for Cable Management
Z11 Plus supports bottom PSU installation and provides an aperture for cable management to make better use of interior space.
Black Interior Coating
The interior of chassis is coated black to provide a sense of unity and elegant design.
Anti-Vibration Rubber Stand
Anti-Vibration Rubber prevents noise and also keeps the system safe from water or other liquid.
Tool Free HDD Installation with Anti-Vibration Rubber
The server-type Tool-Free HDD Mount Trays allow easy HDD installation/removal and maintenance
Spacious Interior for 290mm Card Installation
The interior has been designed to be spacious for easy installation and maintenance of various components.
Supports Solid-State Drive (SSD)
Space is provided on the back of M/B plate for installing 2.5" HDD/SSD. ? Use the bracket located on the 5.25" bay.
Separate Apertures for Convenient CPU Cooler Installation
Separate apertures for CPU cooler are provided for convenient CPU cooler installation without having to remove motherboard from case.
3-in-1 Bracket Provided
3IN1 Adapter Tray is provided for installing FDD / 3.5" HDD / 2.5" HDD/SSD
Rear Tube Apertures for Liquid Cooling Systems
Tube apertures are provided at the rear of the case for convenient water cooling set-up and maintenance.
Includes
- Main Unit
- Stand-off
- M/B, FDD, SSD Mounting Screws
- PSU/PCI Slot Mounting Screws
- ODD Hand Screws
- HDD Mounting Screws
- HDD Anti-Vibration Rubber
- HDD Hand Screws
- Cable Ties
- CPU Power Extension Cable
- Card Holder PCI Bracket
- SSD Tray
- User's Manual
- Enclosure Type ATX Mid Tower
- Dimensions 260(W) x 498(H) x 525(D)mm
- Weight 7.4kg
- Material Plastic, Steel
- Motherboard Compatibility Standard ATX / Micro ATX
- Power Supply Compatibility Standard ATX / ATX12V
- VGA Compatibility Full Size (up to 290mm)
- Expansion Slot 7
- Drive Bay External 5.25' 4 / Internal 3.5" 5 / External 3.5' 1 (Convertible 1 x Internal 3.5" or 1 x 2.5" SSD) / Internal 2.5" 1 /
- Cooling Component: Front 120? or 140? x 1 (120? Blue LED Fan x 1 built-in) / Rear 120? x 1 (120? x 1 Standard Fan built-in) / Top 120? or 140? Fan x 2 (120? Blue LED Fan x 1 built-in) / Side 80? x 2 (80? Standard Fan x 2 built-in) / Bottom 120? or 140? x 1 (optional)
- Side Acylic Tuning O
- I/O Ports Mic x 1, Headphones x 1, USB 2.0 x 2, USB 3.0 x 2
- Color Black
Front mesh cover for high cooling performance
The front mesh bay cover provides cool air into the system while dust filters prevent dust from entering. -
Zalman's powerful HDD cooling solution
Interactive cooling system: Hot air generated from HDD is expelled through both sides. Cooling performance is maximized for HDD cooling, and the overall PC exhaust is increased. -
Top air vent exhaust/tuning
For user convenience, top air vents expel exhaustive air from the top cooling fan. In addition, translucent acryl vents are effective for tuning. -
Side-panel acryl tuning
Dynamic side acryl tuning is provided for users to view the interior of gaming system. -
Supports dual USB 3.0 ports
I/O module provides dual USB 3.0 ports for user convenience and expandability. -
Dust filters for front and bottom of system and PSU
Dust filters in the front and bottom mesh covers prevent dust from entering the system and keep the internal components dust-free. -
Black interior coating
The interior of chassis is coated black to provide a sense of unity and elegant design. -
Anti-vibration rubber stand
Anti-vibration rubber prevents noise and also keeps the system safe from water or other liquid. -
Separate apertures for convenient CPU cooler installation
Separate apertures for CPU cooler are provided for convenient CPU cooler installation without having to remove motherboard from case. -
Rear tube apertures for liquid cooling system
- Zalman Z11 Plus - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- Black
- I/O Connectors
- 2 x USB 3.0 , 2 x USB 2.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX
- System Cabinet Features
- Screwless drive bays, removable side panel, front airhole, meshed front panel, front dust filter, floor dust filter, rear dust filter, water cooling holes, bottom mounted PSU holder
- Power Device
- No power supply (ATX12V)
- 26 cm x 52.5 cm x 49.8 cm
- 7.4 kg
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- ATX, microATX
- Internal Bays Qty
- 6
- Front Accessible Bays Qty
- 5
- Product Material
- Aluminium
- Black
- Cooling System
- Front: 120 mm fan x 1 / intake / blue LED , Rear: 120 mm fan x 1 / exhaust , Top: 120 mm fan x 1 / exhaust / blue LED , Bottom: 120/140 mm fan mount x 1 , Side: 80 mm fan x 2 / exhaust
- Expansion Bays
- 4 (total) / 4 (free) x front accessible - 5.25" , 1 (total) / 1 (free) x front accessible - 2.5" / 3.5" shared , 5 (total) / 5 (free) x internal - 3.5" , 1 (total) / 1 (free) x internal - 2.5"
- Expansion Slots
- 7 x Expansion Slot
- 2 x USB 3.0 , 2 x USB 2.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Included Accessories
- 3.5" to 2.5" bay adapter, cable ties
- Power Device
- No power supply
- Specification Compliance
- ATX12V
- Max Supported Qty
- 1
- 26 cm
- 52.5 cm
- 49.8 cm
- 7.4 kg
