Yale Smart Home Alarm, View and Control Kit
Quicklinx: D221WS00 Mfr#: SR-340
The Yale Smart Home Alarm, View & Control Kit is a home alarm system built with you in mind, allowing you to arm and disarm your system, view images of inside your home via a PIR Image Camera and turn home appliances on & off remotely (i.e lamp or radio) with the Power Switch, all via your Smartphone.
  • Control via Smartphone - Arm/disarm and configure your alarm anytime, anywhere via your Smartphone.
  • Anti-Jamming - Detects attempts to interfere with the system and triggers the alarm.
  • Remote Viewing - PIR Image Camera captures images and displays on Smartphone
  • Remote Control - Power Switch, turn home appliances on and off from your Smartphone
  • 868MHz Technology - Yale uses a frequency that is tightly controlled, meaning a clearer channel with less interference.
  • Pre-Linked - Yale Smart Home Alarms come with components already linked to the Smart Hub. This makes installing your alarm quick and easy.
  • Part Arming - Set the alarm and secure downstairs while you move freely upstairs.
  • Easy to Fit -There is no need to damage your décor, lift carpets or run cables. All components are self-contained and no wired connections are required between units.
  • Expandable - Add up to 20 devices to tailor the system to your home. ** Up to 6 out of 20 can be PIR Image/Video Cameras.
  • No Monthly Fee - Putting you in control and alerting you directly means there are no monthly fees.
  • Extra secure rolling code transmission
  • 94dB Internal Loud Siren - Within the Smart Hub
  • 104dB External Loud Siren
  • 2 Year Guarantee
  • All batteries Included
Extending Your Yale System
The Yale Smart Home Alarm, View & Control Kit allows you to view images of inside your home using the PIR Image Camera. The system also includes a Power Switch to turn home appliances on and off remotely (i.e lamp or radio). You can even add a Yale Smart Lock to your front door, controlling them all from your Yale Smart Home Alarm App.
The Yale Smart Home Alarm App gives you control of your alarm system from your Smartphone. Download the Yale Smart Home Alarm App for complete peace of mind and knowledge that your home is secure. You can check your home anytime, anywhere via the App, and when the system is connected to a PIR image camera you can receive picture alerts and notifications if the alarm is triggered.
Inside the box
  • Smart Hub x 1
  • Siren x 1
  • Dummy Siren x 1
  • PIR Motion Detector x 2
  • PIR Image Camera x 1
  • Door/ Window Contact x 2
  • Key Pad x 1
  • Power Switch x 1
  • Fixing Pack
  • Batteries
Set-Up Requirement:
For use in home with broadband connection. Homes with a router required with one free wired network port.
Smartphone Compatibility:
iOS 9.0+ and Android 4.2+ Internet connection required.
  • Control via smartphone
  • Remote viewing
  • Remote control
  • 868MHz technology
  • Pre-linked
  • Part arming
  • Easy to fit
  • Expandable
    Add up to 20 devices to tailor the system to your home. Up to 6 out of 20 can be PIR Image/Video Cameras.
Yale Smart Home Alarm, View and Control Kit SR-340 - home security and monitoring system
Home security and monitoring system
Sensor Type
Door and window, motion
Integrated Components
Siren
Power Source
Battery, power adapter
Package Content
Keypad, camera, siren, 2 x door and window sensors, 2 x motion sensors, power switch, system hub, dummy siren
Max Supported Devices
20
Wireless, wired
Frequency Band
868 MHz, 2.4 Ghz
Camera
Day&Night
Sensor Type
Siren
Power Source
Package Content
20
Wireless, wired - Ethernet
Max Range Indoors
30 m
Frequency Band
868 MHz, 2.4 Ghz
Interfaces Details
LAN
104dB siren, 94dB siren
Camera
Day & Night Functionality
Motion Detection Technology
Motion Sensor
Detection Mode
Passive infrared (PIR)
Detection Range
12 m
Detection Angle
110 degree(s)
CR2032
Battery Included
Required Qty
3
2 AA batteries, mounting kit, 4 D type batteries, 6 AAA batteries
Product Material
Polycarbonate, ABS plastic
Nominal Voltage
AC 230V
Warranty
WEEE, EN 301 489-1 V1.9.2, EN 301 489-3 V1.6.1, EN 300 220-1 V2.4.1:2012, EN 300 220-2 V2.4.1:2012, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
-10 °C
0 - 70%
