The Yale Door & Window Contact is wireless and easy to pair with your Yale Intruder Alarm System, allowing you to extend your system to tailor it to your individual needs. This accessory will activate the alarm when the door or window that its connected to is opened, it will also work up to 200m away from the control panel.
Effortless installation
The Yale Door & Window Contact is designed for easy setup, requiring no complex wiring, making it an ideal choice for homeowners seeking a hassle-free security solution. -
Extended connectivity
With a wireless connectivity range of up to 200 m in open space, this door and window sensor ensures reliable performance and extensive coverage, providing peace of mind across larger properties.
- Yale Door & Window Contact - door and window sensor
- Product Type
- Door and window sensor
- Power Source
- Battery
- Connectivity
- Wireless
- Product Type
- Power Source
- Battery
- Connectivity Technology
- Wireless
- Max Range Open Space
- 200 m
- Battery Included
