Brand
Yale Sync Smart Home Alarm - Full Control Kit
Quicklinx: G5P9WS00 Mfr#: IA-340
Type: Home security system
Compatible With: Alexa
£332.50 ex VAT
£399.00 inc VAT
The Sync Smart Home Alarm puts you firmly in control, giving you peace of mind, assured that your home is secure and protected. Check from anywhere in the world and receive alerts and notifications when your alarm is triggered, so you'll always be in the know - with no monitoring fees.
The Sync Smart Home Alarm 10 Piece Kit is completely wire-free, eliminating the need for cables running through your property. This means that you have the flexibility to take your home alarm system with you, if ever you move. It is also expandable, so you can design the perfect security solution to suit your home. You can add extra door and window contacts, PIR sensors, smoke alarms, smart plugs, keypads, water leak sensors and if you have a furry friend, you can opt for pet friendly PIR motion detectors. You can add up to 40 accessories and connect them seamlessly to your Sync Smart Home Alarm 10 Piece Kit.
Forget about long-term contracts, when you purchase the Sync Smart Home Alarm 10 Piece Kit you aren’t tied into any monthly rolling or monitoring fees.
What's in the box? The Yale Sync Smart Home Alarm 10 Piece Kit comes with:
1x Smart Hub
1x Yellow Live Siren
1x Yellow Dummy Siren
2x Motion Detectors
2x Door/Window Contact Sensors
1x Keypad
1x Smoke Detector
1x Smart Plug
Yale Smart Living Sync Smart Home Alarm - Full Control Kit - home security system
Power Source
Battery, power adapter
Internet of Things (IoT) Platform
Hue
Intelligent Assistant
Alexa
Package Content
Smoke sensor, smart plug, keypad, siren, 2 x door and window sensors, 2 x motion sensors, system hub, dummy siren
Max Supported Devices
40
Wireless, wired
Frequency Band
868 MHz
Supported Host Device OS
iOS, Android
Power Source
Package Content
40
Wireless, wired - Ethernet
Max Range Indoors
200 m
Frequency Band
868 MHz
Android 4.2 (Jelly Bean) or later, iOS 9 or later
LAN
Status notification, radio jamming detection
Platform
Hue
Alexa
Motion Sensor
Detection Mode
Passive infrared (PIR)
Detection Range
12 m
Brand: Yale
