Yale Conexis L1 Smart Lock - Satin Nickel
Quicklinx: G5RSWS00 Mfr#: SD-L1000-SN
Type: Smart Lock
Compatible With: [N/A]
£165.84 ex VAT
£199.00 inc VAT
Open the door to your world with the Conexis L1 Smart Door Lock. The Smart Door Lock that puts you fully in control giving you the freedom to secure your home without the need for a key.
  • Control via smartphone
    Configure, Control and unlock your Smart Door Lock from your smartphone via our secure Bluetooth App.
  • Keyless
    Say goodbye to keys, Open your Smart Door lock via your smartphone, Key Card or Key Tag.
  • Simple to fit
    Engineered for easy installation. Fits all 92mm centered multi-point locks.
  • Security as standard
    Built in tamper alarm, PAS24 accredited.
  • Battery operated
    Powered by 4 AA batteries and a warning when they're running low.
  • Battery backup
    A 9v battery connection port can be used to power the Smart door lock in the event of flat batteries.
  • Secure push & turn thumbturn
    Engineered to give additional convenience and security to your door.
Yale Conexis L1 - door lock - satin nickel
Door lock - smart lock - electronic
Wireless - Bluetooth
Satin nickel
Door lock - electronic - smart lock
Wireless
Package Content
Batteries, key fob, mounting hardware, key card
Low battery indicator, controlled via smartphone, Twist & Go
4 x AA type
Satin nickel
2 years
Compatible Door Thickness
44-70 mm
Type: Smart Lock
Brand: Yale
