XIGMATEK Asgard Chassis
Quicklinx: 77R3WS00 Mfr#: CPC-T45UB-U01
As the country of Gods, the inviolable Asgard is the world's first black coating entry-level chassis - milestone. Furthermore this chassis is supplied with 1 x 120mm preinstalled black fan, and 3 more fans can be mounted in different areas for best possible airflow. 4 x 5.25" bays will be able to house all your optical drives, but also 5 trays for your 3.5" HDDs are available so you can feel free by "DIY". Tool free design and a "gorgeous" outlook are only a few points why this chassis is a "must" not only for enthusiast but also for PC beginners.
XIGMATEK Asgard - tower - ATX
System cabinet
Tower
Pure black
I/O Connectors
2 x USB 2.0 , 1 x audio line-out , 1 x microphone
Installed Fans Qty
1
Supported Motherboards
ATX, microATX
System Cabinet Features
Screwless drive bays
18.5 cm x 47.5 cm x 40.8 cm
Tower
Max Mainboard Size
ATX
ATX, microATX
Internal Bays Qty
5
Front Accessible Bays Qty
5
Pure black
Fans
Front: 1 x 12 cm - (1 installed) , Rear: 1 x 12 cm - (0 installed) , Side: 2 x 12 cm - (0 installed)
Expansion Bays
4 (total) / 4 (free) x front accessible - 5.25" , 1 (total) / 1 (free) x front accessible - 3.5" , 5 (total) / 5 (free) x internal - 3.5"
Expansion Slots
7 x Expansion Slot
2 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
18.5 cm
47.5 cm
40.8 cm
