Xerox ColorQube 8880ADN Colour Solid Ink Printer
Quicklinx: 9X75WS00 Mfr#: 8880_ADN?GB
The ColorQube 8880 ADN Solid Ink Color Printer means big savings on color printing thanks to its incredibly low total cost of ownership. You get a high-volume, no-fuss, waste-conscious printing solution that delivers exceptional color quality, consistently.
  • Color for black-and-white prices
    You can afford to print all your documents in attention-grabbing color.
  • Only pay for the color you use
    With flexible pricing plans, you'll stop paying expensive per-page prices for low-coverage documents.
  • The print volume advantage
    If you print at least four reams of paper each month, the ColorQube 8880 ADN will deliver a total cost of ownership that's hard to beat.
  • Save storage space
    Compared to toner, solid ink's smaller packaging is small enough to fit in a desk drawer.
  • Spend less on paper and ink
    Get standard two-sided printing and the N-up feature, which prints multiple pages on a single sheet.
  • Less waste, less environmental impact
    Packaging for the printer and Solid Ink sticks generates much less printing waste, lower life cycle energy demand and a smaller carbon footprint than comparable laser printers.
  • Earth Smart print driver settings
    Easy-to-use print-driver gauge allows you to choose the most environmentally conscious print settings, such as two-sided printing.
  • Optimize energy usage
    Intelligent Ready technology learns your workgroup's usage patterns and moves to low-power mode when you're least likely to use it.
  • More color performance
    Solid Ink gives your documents rich, vibrant colors on all media, including recycled paper. PANTONE approved solid-color simulations and Xerox color correction technology deliver results that always match your expectations. Print when you're ready. A first-page-out time as fast as several seconds means your print job's typically ready by the time you walk to the printer.
Xerox ColorQube 8880_ADN - printer - colour - solid ink
Printer Type
Workgroup printer - solid ink - colour
27.4 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 51 ppm - colour
Image Enhancement Technology
FinePoint 2400
Automatic Duplexing
USB, Gigabit LAN
1 GHz
RAM Installed (Max)
1 GB (2 GB)
Language Simulation
PCL 5C, PostScript 3, PDF
Media Type
Envelopes, transparencies, labels, plain paper, card stock, punched paper
Total Media Capacity
625 sheets
Media Handling
100-sheet multipurpose tray, 2x 525-sheet input trays
Monthly Duty Cycle (max)
120000 pages
Print server
UNIX, Microsoft Windows XP, HP-UX 11i, SunSoft Solaris 9, Microsoft Windows Server 2003, IBM AIX 5.x, SunSoft Solaris 10, Microsoft Windows 7, Red Hat Fedora Core 1, HP-UX 11, Novell Open Enterprise Server, Microsoft Windows Vista, IBM AIX 6.1 or later, Red Hat Fedora Core 5, SuSE Linux 10.x, Microsoft Windows Server 2008, SuSE Linux 11.x
1-year warranty
40.6 cm x 52.1 cm x 36.8 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, Gigabit LAN
FinePoint 2400
Automatic Duplexing
PostScript Support
Standard
First Print Out Time Colour
5 sec
Language Simulation
Colour Management Features
PANTONE Digital Color
Media Handling
1 GHz
RAM
RAM Installed (Max)
1 GB / 2 GB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
Legal (216 x 356 mm), 76 x 127 mm
Media Weight
60 g/m² - 220 g/m²
625 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 525 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Max Media Capacity
2200 sheets
Output Trays Capacity
350 sheets
Duty Cycle
120000 pages
Print server
Remote Management Protocol
HTTPS
Security Protocols & Features
IPsec, 802.1x, IP filtering, SSL 3
1 x USB - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x solid ink (black) - up to 3200 pages ISO/IEC 24711 , 1 x solid ink (cyan) - up to 3200 pages ISO/IEC 24711 , 1 x solid ink (magenta) - up to 3200 pages ISO/IEC 24711 , 1 x solid ink (yellow) - up to 3200 pages ISO/IEC 24711
GOST, EN55024, EN55022 Class A, RoHS, UL 60950-1, EN 60950-1, FCC Part 15 A
Power supply - internal
Frequency Required
50/60 Hz
252 Watt
Power Consumption Stand by
104 Watt
Power Consumption Sleep
47 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site
10 °C
32 °C
10 - 80% (non-condensing)
Sound Emission (Idle)
31 dBA
Sound Emission (Operating)
59 dBA
40.6 cm
52.1 cm
36.8 cm
27.4 kg
Width (Shipping)
55.9 cm
Depth (Shipping)
67.3 cm
Height (Shipping)
54 cm
Weight (Shipping)
34 kg
