The VersaLink C600 color printer represents the definition of exceptional performance and unbeatable reliability. Cloud-connected, mobile-ready, app-enabled, and easy to customize, the C600 is your modern workplace assistant - transforming the way you work today, while ensuring you'll stay one step ahead tomorrow.
Reliable productivity and peace of mind
Right out of the box, you'll count on your VersaLink C600 to consistently and flawlessly perform the tasks that make your business work more efficiently. From IT-free installation wizards, to step-by-step configuration options, you're ready to go - hassle free. Completely re-engineered for superior reliability, the VersaLink C600 features a hardware design with fewer moving parts, and a more advanced Hi-Q LED print head. VersaLink devices are loaded with features and time-saving Xerox technologies designed to speed up information sharing and reduce inefficient workflows. Ensure information accuracy with Scan and Fax preview, and do more with scanned documents with built-in optical character recognition (OCR). When it comes to safeguarding critical information, VersaLink devices deliver a spectrum of stringent security features, including Secure Print and card authentication to control access. Count on superior print quality to make your work look its best. A print resolution of up to 1200 x 2400 dpi delivers sharp text and fine line detail, plus exceptional color vibrancy. -
Easy and efficient
With the customizable, capacitive 5-inch color touchscreen, you can tap, swipe and pinch your way through tasks and functions with mobile-like ease. Speed through tasks by saving common settings as presets for simple, single-touch job setup. With Simple ID, individual users and groups enter a user ID and password once, and then enjoy fast, secure, easy access to task-specific presets and commonly used apps on a personalized home screen. -
Mobile freedom and app-based flexibility
The VersaLink C600 color printer gives you the freedom to work where and how you want - with out-of-the-box connectivity to Google Drive, Microsoft OneDrive and Dropbox. The ability to connect and print from multiple devices is key for today's worker, and VersaLink devices meet the challenge with Apple AirPrint, Google Cloud Print, Xerox Print Service Plug-in for Android, Near Field Communication (NFC) Tap-to-Pair and Mopria, plus optional Wi-Fi and Wi-Fi Direct.
- Xerox VersaLink C600V/DN - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 29.4 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 55 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 55 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 53 ppm - B/W - A4 (210 x 297 mm) , Up to 53 ppm - colour - A4 (210 x 297 mm) , Up to 45 ppm - B/W - Legal (216 x 356 mm) , Up to 45 ppm - colour - Legal (216 x 356 mm) , Up to 52 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 52 ppm - colour duplex - ANSI A (Letter) (216 x 279 mm) , Up to 50 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 50 ppm - colour duplex - A4 (210 x 297 mm) , Up to 26 ppm - B/W duplex - Legal (216 x 356 mm) , Up to 26 ppm - colour duplex - Legal (216 x 356 mm)
- Max Resolution (B&W)
- 1200 x 2400 dpi
- Max Resolution (Colour)
- 1200 x 2400 dpi
- Max Resolution Class (B&W)
- 1200 x 2400 dpi
- Max Resolution Class (Colour)
- 1200 x 2400 dpi
- Automatic Duplexing
- Interface
- Gigabit LAN, USB host, NFC, USB 3.0
- AirPrint Enabled
- Preview Screen Size
- 5"
- Processor
- 1.05 GHz
- RAM Installed (Max)
- 2 GB
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, HP GL, PDF, XPS, TIFF, JPEG
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper, card stock, punched paper, preprinted paper
- Total Media Capacity
- 700 sheets
- Media Handling
- 150-sheet bypass tray, 550-sheet input tray
- Monthly Duty Cycle (max)
- 120000 pages
- Recommended Monthly Volume
- 15000 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Red Hat Enterprise Linux, Microsoft Windows Server 2008 R2, HP-UX 11i v3, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Apple MacOS X 10.10, Microsoft Windows 7 / 8 / 10, Apple MacOS X 10.11, Oracle Solaris 11.3, IBM AIX 7.2, Red Hat Fedora Core 24, SUSE Linux 13.2, Apple macOS 10.12
- Pricing Type
- Sold
- 42.74 cm x 46.55 cm x 44.34 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Touch screen
- 5"
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 2400 dpi
- 1200 x 2400 dpi
- 1200 x 2400 dpi
- 1200 x 2400 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 4.7 sec
- First Print Out Time Colour
- 5.1 sec
- Fonts Included
- 136 x PostScript , 83 x PCL
- Media Handling
- Processor
- 1.05 GHz
RAM
- 2 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- Media Weight (lbs)
- 16 lbs (Bond) - 43 lbs (Cover)
- 700 sheets
- Media Feeders
- Input tray: 1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² - (16 lbs (Bond) (min) - 43 lbs (Cover) (max)) , Input tray: 1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² - (16 lbs (Bond) (min) - 43 lbs (Cover) (max))
- Max Media Capacity
- 3250 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 120000 pages
- 15000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, HTTP, HTTPS
- LDAP, Secure Print, SSL, Apple Bonjour, TLS, IP filtering, port blocking
- Connections
- USB 3.0 , Gigabit LAN - RJ-45 , USB host
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
- FIPS 140-2
- Pricing Type
- Sold
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 800 Watt
- Power Consumption Stand by
- 85 Watt
- Power Consumption Sleep
- 0.7 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 10 °C
- 32 °C
- 15 - 85%
- Sound Emission (Idle)
- 33.5 dBA
- Sound Emission (Operating)
- 57.4 dBA
- 42.74 cm
- 46.55 cm
- 44.34 cm
- 29.4 kg
- Width (Shipping)
- 58 cm
- Depth (Shipping)
- 63.4 cm
- Height (Shipping)
- 60.7 cm
- Weight (Shipping)
- 35 kg
