Xerox VersaLink B605V S Mono Laser Multifunction Printer
Quicklinx: G1LTWS00 Mfr#: B605V_S?GB
For a black-and-white printer or multifunction printer, the VersaLink B605 is anything but basic. In fact, VersaLink sets a standard for what you can expect in workgroup productivity from Xerox. Home or away, this highly configurable, cloud-connected workplace assistant delivers amazing capabilities that go far beyond the competition - at a competitive price.
  • Easy, smart and secure
    Right out of the box, you'll count on your VersaLink B605 to consistently and flawlessly perform the tasks that make your business work more efficiently. Completely re-engineered for superior reliability, the VersaLink B605 features an advanced hardware design with fewer moving parts, strengthened paper-path components, and a more advanced print head.
  • Customizable, app-based functionality
    With the customizable, capacitive color touchscreen, you can tap, swipe and pinch your way through tasks and functions with mobile-like ease.
Xerox VersaLink B605V_S (B/W)
Printing Technology
LED (monochrome)
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Printing Resolution Class
Scanning
600 x 600 dpi
Display
7"
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76 x 127 mm (min)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper, preprinted paper
Bypass Feeder Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
Gigabit LAN, USB host, NFC, USB 3.0
AirPrint Enabled
AC 230 V (50/60Hz)
Environmental Standards
ENERGY STAR Qualified
Printing Technology
LED - monochrome
Display Diagonal Size
7"
Colour Support
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
2 GB
Hard Disk Drive
250 GB
Copying
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Printing
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF, TIFF, HPGL, XPS, JPEG
Automatic Duplexing
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Original Type
Sheets
100 sheets
Min Media Size
76 x 127 mm
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
150 sheets
Security Protocols & Features
Secure Print, SSL, TLS, Secure Fax, IP filtering, port blocking, AES-256, Secure Scan, Secure Email
AC 230 V (50/60Hz)
ENERGY STAR Certified
10 °C
32 °C
15 - 85%
